low coolant and oil temp?
Old Feb 2, 2007 | 01:35 AM
98A4TQ's Avatar
Default low coolant and oil temp?
Hello everyone. From what I learned from searching on the forum. It seems my thermostat maybe bad. My coolant temp doesn't rise above to maybe 1/4 the way up and my oil barely heats up at all. I have no fault codes on the computer. Also I just changed my oil today and it had a gasoline scent to it. Does anyone think because the car is not warming up normally that all the gas is not burning throughly and the remainder is in the oil. My heat is warming up good though so im thinking the thermostat may be good still. I just had the timing belt changed 10000 miles ago. Any input is appreciated.
Old Feb 2, 2007 | 07:43 PM
98A4TQ's Avatar
Default RE: low coolant and oil temp?
Just did my thermostat in 20 minutes, car running at normal opp. temp . heat comes out even hotter now. Good to go.
Old Feb 2, 2007 | 07:51 PM
techbod's Avatar
now thats the sort of fix I like
Old Feb 3, 2007 | 11:04 AM
david9999's Avatar
Thermostat is stuck open.
Old Feb 3, 2007 | 02:57 PM
wood_e's Avatar
Nice fix! Your thermo was stuck and not allowing the engine to get up to temp. It was dumping fuel into the oil because it was still in the "warm up" stage.
Old Nov 9, 2007 | 12:11 AM
The Russian's Avatar
hmmmm.... i'm having similar problem ish... it started right after i got my APR chip, so i just figured it was running really rich, whcih it is, in like the 10's and 11's, but yeah when i'm crusing thorugh town it stays at like 1/4 not 1/2, but when i drive it hard it warms up to the 1/2 mark, also at stoplights the temp starts creeping up to the 1/2 mark, but then the moment i start rolling it goes right back down to slighly above 1/4, and oil temp from what i noticed is at like 175'ish is that thermostat?
Old Nov 9, 2007 | 12:23 AM
Bogie's Avatar
Sounds like the same symptoms...
Old Nov 9, 2007 | 12:38 AM
****, haha, ummm how hard is it to change a thermostat? any write up ups on it? and how bad is it for teh car? cuz i'm goign to a race track on sunday... non refundable... lol
Old Nov 9, 2007 | 12:50 PM
a42point8awd's Avatar
You'll be fine at the track with a stuck open t-stat, just give it plenty of time to warm up before you start beating on it. Now, if it sticks closed thats obviously another matter, or if its stuck partially open that could cause problems as well. My bet is that once you are racing it hard the temp will stay right around 1/2.
Old Nov 9, 2007 | 01:04 PM
sweet thanks, i'll just keep an eye open for the temp gauge, and ordering a new one from ECS today, so i can replace it next week. before i take it ralying in the mountains. hehe.
