lowering springs
Old Feb 5, 2005 | 08:47 PM
thintzen's Avatar
Default lowering springs
can i use lowering springs on a 98 1.8t a4 with the factory struts?
i wanna lower the car a bit but i dont want to use aftermarket struts!
Old Feb 6, 2005 | 01:11 AM
trailboss's Avatar
Default RE: lowering springs
Yea you can but it's pointless. Just save and get a whole kit. You will end up installing the springs and about 4-6 months your struts will start to fail, probablly blow the seals. Not only that, once you lower your car you have to get an alignment. Then if you change it again then you have to get another alignment.
Old Feb 6, 2005 | 05:20 AM
aaronamericahall's Avatar
not a good idea but I'm going to do it probably next week me and my buddy are going to do the work at his shop and if the struts fail within the 6 months I'll just purcahase the struts and get it done all over again since its so easy.
Old Feb 6, 2005 | 06:25 AM
PandaXpress's Avatar
save up and buy a damper system
Old Feb 7, 2005 | 12:59 PM
I am going to replace my strut mounts too they often wear out after so many miles and makes the car sound like the struts are out.
Old Feb 8, 2005 | 06:40 PM
thintzen's Avatar
even if im only lowering the car 1.25 inches, which isnt much at all?
Old Feb 8, 2005 | 10:06 PM
i'm going 2" with stock struts but like I said I'm getting it done free but my personal opinion about this is yes it will be ok but I know I'm wrong from the guys told me here.
Old Feb 10, 2005 | 03:34 AM
apg96's Avatar
just break down and buy a package. Maybe even some coilovers. If u just buy the springs the sturts will eventually break and may even cause more damge and cost more than just replcing them now.
kwheels
Oct 28, 2013 10:23 AM
Quattro190
Aug 11, 2008 11:57 AM
christian a4
Aug 8, 2008 02:34 AM
tocame21
Mar 30, 2007 06:16 PM
///A4
Aug 12, 2005 06:44 AM
