MAF and CEL 2000 A4 Quattro
Old Jan 14, 2008 | 02:33 PM
hartsoe1's Avatar
Default MAF and CEL 2000 A4 Quattro
Greetings, newbie here. I've had this car for a few months with good luck so far. Have a CEL on the 2000 a4 Quattro 1.8 with ATW engine and I've searched the database here but need something more specific. AZone read a P1128 code for me. Where is my MAF? On the passenger side, there is a sensor in my air box (just added a new filter and saw that), under the driver's side head light there is a sensor on the outlet side of the intercooler (I guess that is the intercooler), and another sensor after the throttle body (right?) at the intake manifold. Do I just dump the $100 and buy the new MAF and assume it is the problem? I'm new to turbos so don't know my way around yet. see pix.
Thanks,
CH
[IMG]local://upfiles/30041/A83620E33B444C1880E6F76B26C4C6FC.jpg[/IMG]
[IMG]local://upfiles/30041/B5290D9ED8C348A3A4FBCE41F13E1801.jpg[/IMG]
[IMG]local://upfiles/30041/5B15A19BB7134662A97CB9CCAA15B22F.jpg[/IMG]
Old Jan 14, 2008 | 02:54 PM
CRAZYHAWK's Avatar
Default RE: MAF and CEL 2000 A4 Quattro
P1128 Long Term Fuel Trim mult., System too Lean.
Check for vacuum leaks.
17536/P1128/004392 - Fuel Trim; Bank 1 (Mult): System too Lean
Possible Symptoms
[ul][*]Malfunction Indicator Light (MIL) active [/ul]
Possible Causes
[ul][*]Mass Air Flow Sensor faulty[*]Oxygen Sensor Control faulty[*]Fuel Injector(s) faulty [/ul]
Possible Solutions
[ul][*]Check Mass Air Flow Sensor[*]Check Oxygen Sensor Control[*]Check Fuel Injector(s[/ul]
Old Jan 14, 2008 | 03:12 PM
hartsoe1's Avatar
Hawk, where is the MAF on my car and what are those sensors shown in my pix?
thanks
Old Jan 14, 2008 | 03:18 PM
Bogie's Avatar
I have the same exact car/engine. I got that code and it was from a leaking vacuum line. don't get the rubber and braided line at the dealer - those tend to rot and break every 2 yrs or so. Get the rubber line similar diameter at Autozone or Advance Auto parts. 8 ft is probably more than enough line, and it should be less than $1/ft.Some attachments likethe oneunderneath the intake manifold are tough to reach,but itis do-able with effort.
Old Jan 16, 2008 | 08:59 AM
CRAZYHAWK's Avatar
You have to remove the air filter box to remove the MAF.
Start by checking for vacuum leaks.
Old Jan 16, 2008 | 01:04 PM
brrman's Avatar
yes - check for vac leaks first. Then you might try cleaning the MAF - search for that procedure.
Old Jan 16, 2008 | 01:09 PM
techbod's Avatar
ill go with vacuum leaks and clear the code and see if it comes back
Old Jan 19, 2008 | 08:44 PM
hartsoe1's Avatar
Aren't there several different diameter vacuum lines under the hood? I'm guessing that everything on the motor that isn't moving liquid, electricity, or has a cable inside is a vacuum line. Thus, I have multiple diameters. So, how did you buy 8 ft and get by?
CH
Old Jan 20, 2008 | 11:42 AM
hartsoe1's Avatar
Hey Bogie, see my question on vacuum lines, since you've done the replacement before.
CH
Old Jan 20, 2008 | 04:16 PM
CoastalA4's Avatar
To answer your pix ?s: Thumb 1 is the connector to your MAF sensor; T2 is your MAP sensor; T3 is your IAT sensor.
Ditto on checking for vacuum leaks. Actually, there are only a couple of generic replacement lines. Your FPR hose, DV hose, etc. The other hoses that could leak are "special" hoses that come pre-molded.
