major headlight problem.....
Old Apr 3, 2005 | 01:38 AM
mainer's Avatar
Default major headlight problem.....
coming home from new york tonite.... i live in maine... i'm driving in vermont going about 65... and then all of a sudden headlights go out.... i manage to stop without hitting anything....
i had the fogs on and wipers etc... i think i had the high beams on at the time....
but anyways now i have no low beams and no fog lights, the fog light switches dont even light up...
and the only way i had high beams was to hold the switch like i was flashing teh high beams... so thats how i drove teh 100 miles home... not much of a choice
i did check all the related fuses and they are all fine......
any ideas/??
p.s. it was raining quite hard most of teh way
Old Apr 3, 2005 | 03:02 AM
skidplatexa4's Avatar
Default RE: major headlight problem.....
test to see if it the headlight switch. I've heard of them going bad before.
Old Apr 3, 2005 | 03:04 AM
mainer's Avatar
how would i do that
Old Apr 3, 2005 | 03:07 AM
If you have a test light or a DVOM at home get to where you can see the wire connections at the switch and test to see if you have an output coming from the switch.
Old Apr 3, 2005 | 03:15 AM
mainer's Avatar
so do u have to take of the steering wheel etc.... to do this?
is it just the contacts like in the crusie control switches that go bad?? my c/c switch is bad too..or corroded
Old Apr 3, 2005 | 03:19 AM
on mine the headlight switch and the c/c switch is on the same switch to test i think you can just drop the plastics on the steering column but to change it out i believe you would have to remve the steering wheel.
Old Apr 3, 2005 | 12:16 PM
david9999's Avatar
I'm not goint to bother to look up wiring diagrams, but do the simple things first.
1. Check the fuse.
2. Spray contact cleaner on the switch and rock it back and forth to see if the contacts are just dirty.
3. If that doesn't work it is likely either the switch or the relay.
Old Apr 3, 2005 | 12:50 PM
CRAZYHAWK's Avatar
David has the right idea. Get the cleaner at Radio Shack.
Old Apr 3, 2005 | 09:01 PM
mainer's Avatar
which relay is it??? i have a friend having the same problem and i believe it is the relay that has gone bad....
and where can i get a relay? and anyone have any idea how much it is?
Old Apr 4, 2005 | 11:16 PM
mainer's Avatar
btt.....
anyone have any ideas??? where can i get a switch and where can i get the relay? i know you guys have bentley manuals.... could you send me some pics possible of which relay it is? and a wiring diagram of the switch etc???
thanks
ohh p.s. napa or sanel auto parts cant get either the switch or relay... so i guess its audi oem only
matthewlawley
May 26, 2015 02:15 PM
A2dak
Jan 6, 2010 11:08 AM
exequiel3k
Sep 1, 2009 01:26 AM
DevilS4
Jul 12, 2006 02:38 AM
smokeU
Jun 5, 2006 04:17 PM
