Making weird squeling noise???
Old Jan 17, 2006 | 02:00 PM
clconversion's Avatar
Default RE: Making weird squealing noise???
quick fix get some belt dressing and spray it on the serp belt if the sound goes away you know it is the belt and will need to be replaced soon
Old Jan 17, 2006 | 05:29 PM
SILVER_B5S4's Avatar
ORIGINAL: tealetm
My guess is that its your rims- if I were you I'd send them my way and the problem will most likely dissapear.
What do you mean..my rims???
Old Jan 17, 2006 | 05:57 PM
tealetm's Avatar
I was just kidding (jokingly saying I want them). It sounds like a belt like the others suggested. Try some stick or spray on belt dressing and see what happens
Old Jan 17, 2006 | 06:23 PM
tip5's Avatar
Is a a real sharp noise coming the engine or more under your car where the suspension is?
Old Jan 17, 2006 | 06:40 PM
glen's Avatar
Default RE: Making weird squeling noise???
Sounds like the fan belt.When the belt starts slipping it squeals. Should be able to tighten it up
or get a replacement.
Old Jan 17, 2006 | 06:45 PM
seahawkfan94's Avatar
ORIGINAL: SILVER_B5S4
ORIGINAL: tealetm
Yea you retard..He wants your rims..basically said he'd take 'em off your hands for you..man...Tosha's really starting to rub off on you..gettin' flighty! But yeah try the spray and see if it works.
Your best friend/real daddy..haha
Old Jan 18, 2006 | 04:54 AM
You know what Mark..now I'm really gonna get kick the **** out of you!
  #18
ORIGINAL: tip5
Almost sounds like it's coming from the passenger-rear area...
Old Jan 18, 2006 | 06:37 PM
  #19
Russ03A4's Avatar
If it's coming from the rear passenger side it could be the fuel pump. I've replaced 2 on my '03 A4 w/ 115,000 miles. It's a low squeal or almost buzzing sound. If the "belt" thing doesn't work out, try this. A dealer should be able to identify it.
Old Jan 18, 2006 | 10:19 PM
  #20
BFlan2001's Avatar
if it's coming from the rear it's most likely a wheel bearing
