Manual Tranny Fluid?
Old Feb 26, 2007 | 08:53 PM
M¥§T's Avatar
Default Manual Tranny Fluid?
ok, I have a few questions. First, I have noticed that my tranny is loud (in my opinion) when switching between gears. For example, if I'm sitting at idle with the windows down,I can hear it as I go into every gear and I was wondering if that was normal. Second, do I have to check the tranny fluid by taking out the fill plug? And last, what is the best tranny fluid to use in a 2002 5-speed??
Thanks Guys
Old Feb 26, 2007 | 10:21 PM
wood_e's Avatar
Default RE: Manual Tranny Fluid?
Audi specs 75w90 GL4 fluid. Once the snow melts here though I'm putting in GM synchromesh semi-synthetic. A lot of VW guys swear by it in 75w90 spec'd transmissions. Audi says the fluid in the transmission is a lifetime fill uh, yeah... right...
Old Feb 26, 2007 | 10:24 PM
BadLuckAudi's Avatar
I used 75w90 when i had to top mine off
Old Feb 27, 2007 | 02:08 AM
sean1.8t's Avatar
ORIGINAL: wood_e
they are referring toautomatic transmissions.. not manual
Old Feb 27, 2007 | 02:11 AM
98A4TQ's Avatar
I changed the gear oil in my cousins with 75w90 GL5 synthetic valvoline brand, his shifts felt smoother and quieter.
edit: check level using fill plug should be about 1/4 inch below plug.
Old Feb 27, 2007 | 02:03 PM
wood_e's Avatar
GL5 is the wrong fluid. Unless it's multi grade GL4/5 it will eat up synchros
Old Feb 27, 2007 | 02:04 PM
wood_e's Avatar
ORIGINAL: sean1.8t
ORIGINAL: wood_e
they are referring to automatic transmissions.. not manual
You have to admit that that is a retarded statement... no fluid is a "lifetime" fluid
Old Feb 27, 2007 | 02:25 PM
oh1a4's Avatar
best fluid: redline mt (gl4) & motul 300
5 qts total front & rear
*need vag tool (or at least the proper anti-tamper tool) for drain plug
Old Feb 27, 2007 | 07:40 PM
david9999's Avatar
All fluids are lifetime fluids. Of course the lifetime will be very short if you don't replace them.
Old Feb 27, 2007 | 09:15 PM
M¥§T's Avatar
1^ on that one....thanks for the info guys!
MXZ1983
Apr 14, 2010 02:35 PM
BretSV
Jul 11, 2009 03:35 PM
Lefty
Apr 25, 2008 03:27 PM
AG A6
Sep 14, 2007 06:13 PM
