Maybe I'm spooked.
Old Jul 15, 2007 | 09:24 PM
Harlemz4_Os's Avatar
Member
Default Maybe I'm spooked.
Hey everyone, itz mee again... yay. So, my coolant light was on like last week. Was looking for G12, but I couldn't find it so I put some prestone 50/50 in the resi. The light went off, and the car drives great but when I speed I see a whitish smoke from my exhaust. I'm just curious if this whitish smoke is bad, and if I need to flush this b.s. out of my vehicle.(which I kind of don't feel like doing.) Also I wanted to know if anyone knew of a site that had shifters and shift covers that look stock for the a4. I need a new **** and I could use a cover too, but I don't want any ricer crap in my audi. 96' B5 auto, if that helps.
Old Jul 16, 2007 | 04:38 PM
Member
Default RE: Maybe I'm spooked.
cough...
Old Jul 16, 2007 | 04:42 PM
smokeU's Avatar
do the flush its pretty easy and will give you peace of mind.
Old Jul 16, 2007 | 04:54 PM
Daskid97's Avatar
If I recall correctly it's a pretty bad idea to mix G12 with regular coolant. A flush is probably a really good idea.
If you do a search on this site you'll probably find some good info on coolant.
Old Jul 16, 2007 | 04:55 PM
Audi A Fizzle's Avatar
flush it. now.
Old Jul 16, 2007 | 06:08 PM
A4 Effort's Avatar
I've beenrunning Prestone 50/50 for well over a year now and i haven't had a lick of problems.
Old Jul 16, 2007 | 06:22 PM
ceelos's Avatar
Member
From what I read on the forums, when you mix pink with green, you get jello.
Old Jul 16, 2007 | 09:53 PM
david9999's Avatar
You can run green in your car for years without problems, but then the metal in the radiator is being eaten away. Get some G12 and distilled water and replace it.
I am more concerned about the low coolant and white "smoke" coming from your exhaust. I'd check your compression to make sure you don't have a blown head gasket. Also check your oil filler cap for coffee and cream coloured sludge.
Old Jul 16, 2007 | 10:04 PM
A4 Effort's Avatar
ORIGINAL: david9999
Kinda lost on this. What is the difference between an Audi's radiator and that of, say, a Chevy? I don't see why if the entire system were flushed of the G12 why you couldn't use a 50/50 mix. I know the manual says "G12 Only", but maybe someone could enlighten me as to why this is?
I know the G12 has "anti-corrosive" properties to it, but shouldn't most coolants contain it?
Old Jul 17, 2007 | 12:13 AM
onepoint8tee's Avatar
ORIGINAL: ceelos
Exactly. The green stuff will work, but should never be mixed with G12. Also the green stuff supposedly doesnt have the same anti corrosion properties as G12. Think about it..... How many stories of leaky/bad radiators have there been in an Audi?? None that I can think of, and they were all probably filled with G12. Its like the fountain of youth for our radiators.. In fact, Im going to go beer bong some G12 [sm=alcoholic.gif]
