MBC
Old Jul 22, 2006 | 07:54 PM
tooxtreme8813's Avatar
Default MBC
I searched and read alot of posts about a MBC valve. But when you install it does it eliminate the N75 valve all together or better yet can you run an MBC without an N75? I plan on buying the one from ecstuning.com and it looks as if it completly replaces the N75 valve.
Old Jul 22, 2006 | 10:22 PM
RLB6's Avatar
Default RE: MBC
Just run the mbc inline with the N75. If not, I'm sure you'll get the dreaded CEL.
Old Jul 22, 2006 | 10:31 PM
RLB6's Avatar
Default RE: MBC
What you do is find the hose coming from the N75 that leads to the wastegate actuator and split it there. Now, add some new hose to the existing hose, with a vacuum connector, that you just split coming from the N75, leading to the mbc input. Connect a hose from the other port off the mbc to the other half of the split hose connected to the wastegate actuator. That's it.
So recap, N75 to mbc, mbc to wastegate.
Old Jul 22, 2006 | 11:57 PM
Jeff's Avatar
Zombie Defense Force
Default RE: MBC
nope dont use the n75. just got turbo----mbc----wastegate and your set
Old Jul 23, 2006 | 12:01 AM
Beer Mod's Avatar
Default RE: MBC
N75 is disconnected, but don't throw it away just leave it pluged in so you don't get a CEL.
The post above is not how I have mine hooked up! It might work like he (ALB6) said but imo he (ALB6) is full of ****.........
Old Jul 23, 2006 | 12:21 AM
RLB6's Avatar
Default RE: MBC
ORIGINAL: Beer Mod
Yep, that would work.
Old Jul 23, 2006 | 04:44 AM
Default RE: MBC
alright so im gonna install the MBC in place of where the N75 vlave was and just leave the N75 plugged in and zip tie it to hold it in place somewhere under the hood
Old Jul 23, 2006 | 09:30 AM
RLB6's Avatar
Default RE: MBC
ORIGINAL: tooxtreme8813
You got it.
