mbc?
Old Sep 26, 2007 | 07:30 PM
4bangin's Avatar
Default RE: mbc?
ORIGINAL: cincyTT
ORIGINAL: EVOLA4
Not scared at all. Matter of fact I almost did it before i chipped. the only reason I chipped was because i knew somebody that hooked me up with the programs, flashloader and injectors. Plus I was trying to keep it nice and reliable at the same time since I am used to driving 150+ miles a day. Don't flame me I was the one who told him to ask you for advise[8D]
You do know that you can use it with the chip right? Its not altering reliablity one bit. Plus like i said before, you can increse/decrese boost and spool faster and hold boost longer. Seems worth it to me
do you have a dyno chart for your car with a a/f recorded? i read your post to the diode,mbcmod and the link you posted to the guy with the same setup and dyno was running stupid lean. is that how lean you are running? do you know how your car is running?
when you post that everything is good with a setup its good to back it up with facts like dyno charts with readings showing what you are claiming is true. i havent found any charts of your own if you have posted can you pls link. thanks
actually that link you provided proves my point exactly.
Old Sep 26, 2007 | 07:47 PM
cincyTT's Avatar
I'm make believe
Default RE: mbc?
No i dont have any dynos, there is no point since its going to be within a few hp as every other car that dyno'd with the same mods. My car is well within check when it comes to a/f ratio, it runs high 12's. You really should take the a/f on that chart with a grain of salt since it is placed at the end of the exhaust and not at the begining,.
I like how you have nothing else to say so you start trying to attack my setup [sm=lame.gif]
BTW, there are TONS of people running the same setup as me, and not one has a problem with it.
Old Sep 26, 2007 | 08:03 PM
Audi_Skydiver's Avatar
Default RE: mbc?
[sm=admin.gif]
Well CincyTT isn't an admin but he is still owning you! HAHA!
You should read more before you start posting stuff on here. He knows his stuff and you don't. Simple enough. I would be running his setup to if I had a map sensor in my car but I don't so I cant.
Josh
Old Sep 26, 2007 | 08:58 PM
4bangin's Avatar
Default RE: mbc?
i am not attacking your setup exactly just looking for some good hard data instead of hear say.so dont start crying.
also how am i getting owned actually cincytt owned himself in that thread he posted. why would you post a thread that proves a lean (unsafe) condition. i loled ir on that one.
and its not that much of a difference using a o2 at the back that has been proven on many different cars maybe a difference of .5 at most.
dont be scared to seek the truth its out there lol.
Old Sep 26, 2007 | 08:59 PM
Jeff's Avatar
Zombie Defense Force
Default RE: mbc?
your afr are high 12's???? you should tune for 11.5 afr under wot and 14.7 for idle and crusing
Old Sep 26, 2007 | 09:06 PM
kemp_travis's Avatar
Default RE: mbc?
you dont argue with cincyTT......he knows far more than you or i do
Old Sep 26, 2007 | 09:08 PM
Jeff's Avatar
Default RE: mbc?
who me??/
Old Sep 26, 2007 | 09:12 PM
  #18
cincyTT's Avatar
I'm make believe
Default RE: mbc?
ORIGINAL: Jeff
You do realize that mid 12's is where you make the most power right? And im sure he wasnt talking to you.
Old Sep 26, 2007 | 09:13 PM
  #19
cincyTT's Avatar
I'm make believe
Default RE: mbc?
ORIGINAL: 4bangin
Your an idiot. You do know what a cat is right? And what it does? Think about that for a min and get back to me. Dont know what your trying to prove, but your just talking out of your ***
Old Sep 26, 2007 | 09:16 PM
  #20
Jeff's Avatar
Default RE: mbc?
imo thats too lean to be running. i tune for 11.5-2 under wot
