metal rattling??!?
Old May 8, 2007 | 12:34 PM
chitownA4's Avatar
Default metal rattling??!?
I was driving yesterday and i heard this metal rattling..noise. it seems to be like coming from the suspension on the right somewhere..only happens if i hit bumps or little nicks in the road...any ideas?? i tried searching but couldnt come up with much
Old May 8, 2007 | 12:41 PM
chitownA4's Avatar
Default RE: metal rattling??!?
its sounds like something is loose...not sure what it is...im putting on my exhaust today..so im gonna look at it..jsut dont know where exactly to look
Old May 8, 2007 | 12:44 PM
ironman's Avatar
I had a bearing go and it made that noise, do u get any noise while driving a low humm maybe, if yes then id say replace bearing if not you prob need new bushings/control arms
Old May 8, 2007 | 12:54 PM
CRAZYHAWK's Avatar
Shake the car and listen for the rattle.
Old May 8, 2007 | 01:28 PM
techbod's Avatar
possibly the heat shields on the exhaust its common for the plate to rot round the bolts holding them up then you get the rattle,
Old May 8, 2007 | 01:36 PM
chitownA4's Avatar
cool guys thanks for the info..ill look under later today when i put the exhaust on..
Old May 8, 2007 | 01:40 PM
techbod's Avatar
cant understand why they didn't make these things out of stainless then they wouldn rust ( personally I would throw them for what good they are )
Old May 16, 2007 | 04:14 AM
Flarika's Avatar
I get a metallic rattling sound sometimes from the underseat storage bins...very annoying and very hard to silence permanently. Try pushing on the (like you're closing them) and see if that is your problem. Most likely not, but, you never know!
Old May 16, 2007 | 04:23 AM
a3square's Avatar
Member
check you center caps on yours rims
Old May 16, 2007 | 07:53 AM
ironman's Avatar
ORIGINAL: a3square
HUH, there plactic and we are getting a metal rattling noise, I am also getting this noise, i did the bearing 45 min job, and i can here it rattle when i hit bumps
