Misfire counts - 1
I have VAG-Com Lite was was able to chase down a misfire issue. Should I be concerned if the misfire count is 1 and goes back to zero and back to 1 every two minutes at idle. I was in measuring blocks and wanted to check all cylinders and only saw this issue on cylinder 2, all the other cylinders were 0 counts.
The coil packs were changed recently and no CEL is on, other than that it seems to run fine.
Russ Heinrichs
Aug 18, 2021 12:39 PM
Audi Forums Editor
Apr 14, 2014 05:48 PM
A4ENGRSF
Oct 9, 2010 09:49 PM
