Misfire at high torque...
Old Mar 18, 2007 | 06:39 PM
oleafo's Avatar
Default Misfire at high torque...
OK, I've been getting this problem for2 weeks now but still no codes. Whenever I step on it hard it starts to sputter and my guess is it's misfiring, this happens on any gear. Also it runs normal when I don't push it. I replaced the ICU in July with a brand new one so I don't think it's that. I've used ignition cleaner on my last 2 tanks nothing changed. I've replace the check valves in october as well as most of my vac lines. No boost leak noticed on the boost/vac guage.
I NEED HELP!!! This one's got me stumped!
Old Mar 18, 2007 | 07:36 PM
Lazer Viking's Avatar
Default RE: Misfire at high torque...
ignition cleaner ??
stop using that, change your coil packs, and spark plugs
Old Mar 18, 2007 | 07:38 PM
x1rider's Avatar
If you have access to a Vag-Com, you could check the engine controller for misfire "latent" codes, also, you could log your correction factors when you are doing the pulls and see if you are knocking/detonating.
Old Mar 18, 2007 | 08:10 PM
tooxtreme8813's Avatar
its your coil packs vag the car and see which one is causing the problem
Old Mar 18, 2007 | 08:26 PM
oleafo's Avatar
I've vaged the car but so far there's been nothing logged, sigh... Going out to see if I can log something on vag.
Old Mar 18, 2007 | 10:40 PM
theguy1084's Avatar
maybe coils. I have also seen cam adjusters do kind of the same thing. does the car tick really bad at idle(like vavles ticking)
Old Mar 18, 2007 | 10:41 PM
theguy1084's Avatar
A miss almost always sets a light. I guess you could check the MAF too
Old Mar 18, 2007 | 11:03 PM
tractioncontrol's Avatar
Sounds like a vaccume related problem to me.
Old Mar 19, 2007 | 01:29 AM
limptimtim's Avatar
hey, my car is currently doing the same thing however the boost levels arent up to what they are suppsoed to be unless I installed my boost gauge wrong. Anyway, I have been advised by my tuner to replace the coil packs and spark plugs as others have said... and to get my CEL light to come on again I had to just try to just run it a little harder when it misfired, as painful as it is to do. I got misfires in 2 cylinders and a random one but havent been able to figure this one out either...the replaced coil packs did work for a week though!
Old Mar 19, 2007 | 05:30 AM
oleafo's Avatar
OK, I finally got it to throw a CEL and it was for multi cylinder misfire 16684 and cylinder 2 16686 and 3 16687. Just like limptimtim. Then I cleared it and ran it some more and got missfire detected prob low fuel. But at this point I really was low on fuel and my get gas now light was on. I changed my plugs last winter, do they only last a year? I've got the NGKs.
Also I was logging engine group 014 and 015and was getting lots of hits in the "count" columns when it was doing the sputtering thing.
And like limptimtim I don't think I'm getting full boost,my max spike isat 16psi... I've got the N75J valve too...
