Missfire on all 6???????
Old Dec 5, 2007 | 08:21 PM
lalo83's Avatar
Default Missfire on all 6???????
I just changed the plugs on my audi bcz the engine light came on and the code was miss fire on cyl #7 so they said it just needed a tune up well now the light just came back on and its a miss fire on all 6 cyl,???????????????????????????????????WHAT DID I DO WRONG?
Old Dec 5, 2007 | 08:25 PM
MissingLink's Avatar
Default RE: Missfire on all 6???????
did you put all the plug wires back in the same way they came out ? is the plug gap correct for your audi? all i have hope it helps
Old Dec 5, 2007 | 08:27 PM
hiwords's Avatar
how the hell do you have a cylinder 7 on a v6? a misfire doesn't only mean a bad plug. it could be your coil pack.
Old Dec 5, 2007 | 08:30 PM
lalo83's Avatar
sorry i meant cyl4 i hit 7 on acident
Old Dec 5, 2007 | 08:32 PM
lalo83's Avatar
well if it was a bad coilhow did it get from one being bad to all 6 in a couple of days
Old Dec 5, 2007 | 08:34 PM
hiwords's Avatar
could be your ICM or ECT. change the ECT and test the ICM. usually the v6 engines don't misfire though. what plugs did you get?
Old Dec 5, 2007 | 08:39 PM
lalo83's Avatar
used the cheapest ngks
Old Dec 5, 2007 | 09:12 PM
hiwords's Avatar
describe in detail how you took the old ones out and put the new ones in
Old Dec 5, 2007 | 10:16 PM
lalo83's Avatar
1st i took the passenger side ones off, i removed the air intake then the wire harness to the 3 coils then went front to back then did the same to the other side.
Old Dec 5, 2007 | 10:21 PM
hiwords's Avatar
did you tighten the plugs on right? your coilpacks have a screw holding it down right? are they all on snugly? change your ECT too. i'm not sure how much it is for the b6 but the b5 it's only 7 bux.
