More Problems headlight sprayers
Old Sep 19, 2007 | 03:48 AM
PandaXpress's Avatar
Default More Problems headlight sprayers
Well i fixed my coolant leak which was a pain casue it was behind the engine
but you kno wat my car has a bladder problem
now my car is leaking windshield washer fluid[&o]
its leaking it from the head light sprayer
is there a ways to keep the sprayers up or do i have to remove the bumper
Old Sep 19, 2007 | 09:29 AM
hiwords's Avatar
Default RE: More Problems headlight sprayers
wut do u mean by keep the sprayers up? if u take out ur lower grilles u can reach up and there are 2 screws holding them on. mine sort of leaks too but mine is so minor that i don't bother with it
Old Sep 19, 2007 | 11:13 AM
aikibil's Avatar
my passenger side stays up every time. used to be the diver's, but i'm still trying to realign my bumper. anyway, it gets caught on the bumper on the way down. touch it, a slight nudge and it drops into place. not the safest way. there's alot of power pulling down.
Old Sep 20, 2007 | 02:57 AM
dam i guess the next time my car is on the lift ill take a look at it
Old Sep 20, 2007 | 03:17 AM
chaos92287's Avatar
wow sounds identical to my car. let me guess, it was your coolant flange leaking? and i just dont bother with the washer fluid.that crap just gets my car dirty. when my windshields dirty i just clean it at home
Old Sep 20, 2007 | 03:34 AM
ORIGINAL: chaos92287
yup that was it,it was a bitch to find the leak also, i also replaced my crank breather hose at the same time and got reinbursted by audi becasue it was a recall
Old Sep 20, 2007 | 03:44 AM
chaos92287's Avatar
^^is it a recall on mine too?
Old Sep 20, 2007 | 04:01 AM
i dunno i think it was only on the 02s cause they had upgraded crank breather hoses for the laters B6 model
they might cause you probly came with a crap one like mine
Old Sep 20, 2007 | 06:34 AM
99A4NOW's Avatar
What exactly did you do to stop the leak on the coolant flange? Mine was leaking since I bought it two years ago. A few months ago when I did the t-belt I replaced the flange and the o-ring, but it continued to leak. A couple days ago I took it apart again, cleaned it, put and o-ring in, gooped it with some RTV sealant, and let it set up for a day anda half. Still leaks! I'm thinking about finding someone with a 5-axis milling machine that can mill the flange out of aluminum... but I'm sure that wouldn't be cheap (unless I could mass produce them...hmmmm)
Any suggestions would be appreciated.
Old Sep 20, 2007 | 12:20 PM
chaos92287's Avatar
are you sure its the coolant flange then? cuz mine just needed the o-ring replaced but i went ahead and replaced the whole flange since it was only 18 bucks. works perfectly now
