Motor Build
Old Oct 31, 2005 | 12:33 PM
InsaneHatter's Avatar
Default Motor Build
I did some seaching and cant seem to find the exact answer I want.
I am thinking of doing a motor build with a possible compression change. New Pistons/Rods and whatnot.
Anyone know of a cost for this?
My buddy did his 350z for over 5k.
He said it would run 2200-2600 for labor.
I have 92K on my motor now and would like to build it b4 I put the 2871R on it.
Old Oct 31, 2005 | 08:10 PM
PandaXpress's Avatar
Default RE: Motor Build
dahlback has some parts u want but they are pricey
http://www.tjmmotorsport.com
Old Oct 31, 2005 | 08:49 PM
flyboy's Avatar
As for the new pistons and rods, I don't know but you could probably just deck the block and zero it out and that should bring it up quite abit.
Old Oct 31, 2005 | 09:48 PM
GraffixWB's Avatar
don't worry about buildin the motor if you got an AEB. Just get rods. That's all you need. 716hp was made on an AEB with just rods . they are strong as hell compaired to the other 1.8ts (xcept 225 tt)
Old Oct 31, 2005 | 09:51 PM
Yuikio's Avatar
Yeah, you don't need to build your engine for a GT2871. Rods are the weak point, other than that, AEBs are rock solid.
Old Nov 1, 2005 | 12:25 PM
audiboy1618's Avatar
Rods and a good cam and your golden...
Old Nov 1, 2005 | 01:25 PM
Rods and cams it is then...
What are we talking for labor then? Is it hard to replace rods/cams?
Might as well ahve them do a TB when they are in there.
Old Nov 1, 2005 | 04:57 PM
well.. i dont think labors gonna be too different on replacing rods from ... doing a motor build. You have to disassemble the motor anyway.
Might as well have it built with pistons/rods. I have a 92K mile car and that would give me alot more life outta it
Old Nov 1, 2005 | 05:37 PM
ParkCityCustoms's Avatar
Where is a good place to find some good cams. I found the forged rods on atpturbo.com but I can't find the cams anywhere. Also is there a website or should i just go to the dealership to get like a complete gasket set for a rebuild. Thanks in advance.
Old Nov 1, 2005 | 07:46 PM
BaconBait's Avatar
www.ecstuning.com has some piston and rod kits along with individual parts.
