mustang MAF
Old Nov 6, 2004 | 03:33 AM
glenkarl's Avatar
Default mustang MAF
is this really ture that you can use a mustang MAF on a 2.8L 12v??????
and does anyone know how to pop the fake wood off so i can get to the switchs where the fog lights are because there is a dead switch closest to the stearing weel and i would like to put in a toggle switch in there but i don't want to break the fake wood what can i do ???????
Old Nov 6, 2004 | 06:56 AM
SlimChriz's Avatar
Default RE: mustang MAF
If your talkin bvout the peice that goes around the radio and climate control also on my 97 you have to take out the radio to access two bolts
Old Nov 6, 2004 | 08:02 AM
Jestnomen's Avatar
6th Gear
that switch can be popped out with a jewlers screw drivers on each side.
Old Nov 6, 2004 | 08:18 PM
David_K's Avatar
yes you can fit a mustang maf to any car. its just the good ones cost like $350
Old Nov 7, 2004 | 05:34 PM
audihere's Avatar
Banned
so will it work with a 1.8t
Old Nov 7, 2004 | 06:02 PM
audiboy1618's Avatar
"yes you can fit a mustang maf to any car."
Old Nov 7, 2004 | 06:21 PM
David_K's Avatar
The mustang MAF from the '87-'93 model 5.0 are the most universal part in automotive history. all you need to know is how to solder and the wiring diagram for the A4 MAF. SUe the 70mm or the 76mm mustang MAF
Old Nov 7, 2004 | 07:09 PM
audihere's Avatar
Banned
do u know where i can find this info? also i take it u cant just use the fillinent from the audi maf bc its not for that size right
Old Nov 7, 2004 | 09:48 PM
Jestnomen's Avatar
6th Gear
good luck not getting a check engine light.
Old Nov 7, 2004 | 10:18 PM
trailboss's Avatar
I remember someone saying in a different thread get the most expensive one, its expensive for a reason. Not quoting anyone or pointing fingers but like Jestnomen said, good luck not getting a check engine light.
