mustang MAF
Old Nov 9, 2004 | 01:14 PM
  #21
hb972.8q's Avatar
Default RE: mustang MAF
yep that is what it is mass air flow
the inside of one.... geting it bored gets rid if the chunk of metal in the center
Old Nov 9, 2004 | 05:41 PM
  #22
David_K's Avatar
heres a pic of the mustang MAF
[IMG]local://upfiles/1969/3DF49AC2A1D34CD5A0DAEC577E245CA3.jpg[/IMG]
Old Nov 9, 2004 | 06:45 PM
  #23
Jestnomen's Avatar
6th Gear
The MAF is conposed of two parts. First there is the MAF housing, which is the metal tube piece you see above. Inside the tube in the middle of the MAF housing is where the MAF sensor goes. The tube is called a "sampling tube". The sensor inside has two heated elements that measure the amount of air traveling into the engine. It does this to compute the amount of fuel that is needed to make the "right mixture". You also might be interested to know that on the exhuast there are 4 sensors called "oxygen sensors". They measure the ACTUAL mixture ratio coming out of the engine. The computer (ECU) decides if the maf is lying or accurate by reading the o2 sensors, it then makes corrections as needed to maintain the correct fuel/air mixture.
Old Nov 9, 2004 | 11:46 PM
  #24
David_K's Avatar
your right jestnomen i forgot to include the actual meter
This will be the actual unit i will use. hey jestnomen im not trying to increase the air flow to the point modifications need to be done to the fuel im just trying to position the filter in a place where it can access cold fresh air
[IMG]local://upfiles/1969/A6D7A9C52465420DA68D2574616242BE.jpg[/IMG]
Old Nov 10, 2004 | 01:08 AM
  #25
David_K's Avatar
Heres a very expensive "string" Universal MAF
Old Nov 10, 2004 | 01:09 AM
  #26
Jestnomen's Avatar
6th Gear
why do you need to move the maf's location?
Old Nov 10, 2004 | 01:13 AM
  #27
David_K's Avatar
NOt sure. Just experiementing. its a prototype. it might not even see production.
On a personal note. I found your post. I searched for it and i moved it but it didnt show up. Im going to log out and see if it appears when im a guest. remember that post that we couldnt see as Mods but as guest we could see it
Heres the pic of the "string" MAF
[IMG]local://upfiles/1969/B87E08401CEA45ABB1770D6F8B320541.jpg[/IMG]
Old Nov 10, 2004 | 01:15 AM
  #28
Jestnomen's Avatar
6th Gear
WOW, that thing is pretty crazy looking!
Old Nov 10, 2004 | 01:17 AM
  #29
David_K's Avatar
I know right. it looks more like a cheese cutter.
ConroeA4
Oct 20, 2008 08:00 PM
25thmustang
Jul 9, 2007 08:08 PM
quattro/2.8
May 10, 2007 08:05 AM
Bigrigatoni
Apr 20, 2007 12:48 AM
