My 1st Mods to my 2002 A4 1.8T Tip
Old May 29, 2005 | 02:28 PM
peccin's Avatar
Default My 1st Mods to my 2002 A4 1.8T Tip
I am planning to make my 1st mods to the Certified Pre-Owned Audi I just got. All thought and comments are appreciated. Please let me know if i am missing anything. I will be doing this next weekend.
GIAC Chip
GIAC Tip Chip
710N DV
AWE Exhaust
The total for all of this including installation is $1975
Old May 29, 2005 | 02:32 PM
Jestnomen's Avatar
6th Gear
Default RE: My 1st Mods to my 2002 A4 1.8T Tip
Nice choice, sounds like a good plan to me!
Old May 29, 2005 | 02:33 PM
aRIf's Avatar
I am not sure but I think Forge DV is better for chipped cars....
Old May 29, 2005 | 02:47 PM
black991.8tq's Avatar
sounda like ur gettin everything u need, might want to go with a dv that can hold a little more boost
Old May 29, 2005 | 03:01 PM
Jestnomen's Avatar
6th Gear
As far as I know the 710N holds boost just fine with a chipped car. Even if it had half the life of a more expensive DV you'd still be saving money.
Old May 29, 2005 | 03:28 PM
audiboy1618's Avatar
The 710n holds chipped boost fine. Heck, i even ran one with my ko4 for a while, that, it didnt hold.
Old May 29, 2005 | 03:34 PM
peccin's Avatar
What is the K04? How much does that cost and should I consider that instead? What is the difference in performance with the K04 then with the setup I described above in terms of hp/torque/etc? Can I spend the 2K I have for these upgrades more wisely?
Old May 29, 2005 | 05:47 PM
headshok2002's Avatar
I'd do the upgrades you have listed... it'll transform the hell out of your car, and wont destroy your transmission.
umm... check www.ecstuning.com I think they have a k04 kit, if you want to read up about it... but yes, be warned, the tiptronics do not cope well with excessive power. (I think keeping them under 250 hp is wise)
Old May 29, 2005 | 06:03 PM
a4autocrossr's Avatar
a k04 is the turbo that comes in the TT...you can swap out your K03 for a k04..but i;d stick with your setup at the moment. Sounds good.
--E
Old May 29, 2005 | 06:07 PM
Sebass's Avatar
In my search fro exhaust for the tip I was only able to find one place that sells a downpipe (your AWE setup will not have one)...although exhaust in general is an upgrade the downpipe is a very nice chunk of it...tantrum werks was the only place that had em and it needs to be welded in with your new exhaust...it runs $250 and I think is a 2.5" pipe....
