My car had a Flood!!!!!!!!!!!
Old Apr 4, 2005 | 05:56 PM
  #61
Jestnomen's Avatar
6th Gear
Default RE: My car had a Flood!!!!!!!!!!!
can you go to a car wash or take a hose to the car? Might help you troubleshoot a little.
Old Apr 4, 2005 | 10:32 PM
  #62
droo587's Avatar
OMG!!! REPLY ASAP!!!!!!!!!!Im is deep S***!!!!!!!!!!!!! The water is coming somewhere above the rest pedal.... the water actually run over the pedal threw the side of the left drivers side, emptys into the back. Wheres it coming from???? and whats messed up? i cant take apart the bottom of the dash right now cause it already got dark!!!!!AHHHHH
Old Apr 4, 2005 | 10:34 PM
  #63
Jestnomen's Avatar
6th Gear
check the winshield, i'll bet you have a leak in the seal.
Old Apr 4, 2005 | 10:35 PM
  #64
droo587's Avatar
window seal? how can i check it?
Old Apr 4, 2005 | 10:36 PM
  #65
Jestnomen's Avatar
6th Gear
Get your car into a shop, you are going to cause more damage by doing nothing.
Old Apr 4, 2005 | 10:38 PM
  #66
CheckMyVitals's Avatar
i doubt it would coming from under the dash with a leaky windshield. it's more likely the aforementioned firewall seal.
ORIGINAL: 2.8AudiA4
i had this same problem it i you have installed anything through the firewall its prob that if you open you hood look to the right in the back there is a black rubberseal mine was not put back after somone installed my **** from best buy. If you look where your foot rest is on next to the clutch you will see that it is leaking there if its not that its prob the sunroof
Old Apr 4, 2005 | 10:47 PM
  #67
droo587's Avatar
is this seal where the wire for the hood latch run through? I think the **** who installed my alarm didnt put the seal back, where can i buy anoother one?
Old Apr 4, 2005 | 11:02 PM
  #68
BFlan2001's Avatar
dealership, it's probably five bucks...that's not uncommon, stereo installation guys are idiots 90% of the time when you go to places like best buy and circuit city...
Old Apr 4, 2005 | 11:16 PM
  #69
droo587's Avatar
ERRR! ok since all the water was behind the driver seat after i took the carpet off a bit there was about 2 inches of water!!!!!!!!the when i jack the right front of the car up all the water went to that corner of the car and oh boy............. theres so much water i got a cup to get the water out. This is insane!!!!!!!!!!!!!!!this water must have build up of months! over the winter!!! thank god i got that absorber cloth too it helps like crazy.
Old Apr 4, 2005 | 11:19 PM
  #70
you might be replacing the carpet here dude. inhaling mould isn't the greatest hting
