my cars got the squeeks
Old Jan 20, 2006 | 02:16 AM
brent07's Avatar
Default my cars got the squeeks
when i turn my steering wheel something in the front end squeeks ... it will sqeek as long as i am turnig the wheel ... if i'm not it wont .. it is also only 20 degrees outside right now.. any idea what causing it ?
Old Jan 20, 2006 | 02:17 AM
juice88's Avatar
Default RE: my cars got the squeeks
cv joint
Old Jan 20, 2006 | 02:18 AM
brent07's Avatar
so whats that ? .... sorry ... still learning ....
that mean it needs to be replaced ?
Old Jan 20, 2006 | 02:21 AM
tip5's Avatar
Ive heard because we have floating rotors they can squeek everynow and then check up on those.
Old Jan 20, 2006 | 02:22 AM
juice88's Avatar
well how long has it been doing it? if its been over a month, it needs replacing. its the thing behind the rotor that is attached to your steering axle. turn your wheel to whichever side it makes, all the way, and look to see if a rubber accordian looking thing is ripped and grease is every where. if so, get it replaced, but deff not at audi.
Old Jan 20, 2006 | 02:26 AM
brent07's Avatar
it squeeks in both directions ... i'll have to look at them .... they expensive ?
Old Jan 20, 2006 | 02:27 AM
juice88's Avatar
quoted 1200 at audi, what bastards. im supposed to be getting called back from this mechanic i know
Old Jan 20, 2006 | 02:38 AM
brent07's Avatar
woah .... haha ... thats alot .... i was hoping to spend my tax return on doing other maintenence ... not fixin this ... what kind up lube should i use on the cv joints ? i think i'll try that first ....
Old Jan 20, 2006 | 02:40 AM
a4anonymous's Avatar
did you check your power steering reservoir
Old Jan 20, 2006 | 02:46 AM
Matori1.8t's Avatar
ORIGINAL: brent07
Got the sim issue. when turning left my front right squeeks, and when driving normal my front right.. -note i just replaced a suspension (private dealer)- he told me its the bearing and i should wait 10-15 days for it to settle in..
