my fuck!ng headlight went out...
my ****!ng headlight went out...
whats up guys....like it says the headlight bulb went out. the guy i bought the car from said he just replaced them because one went out, so i'm thinking that maybe there's a bigger problem than just the bulbs, what do you guys think? and if it is just the bulb, where's a good place to order one? do they make them in different tints of color? thanks
it's a 2000 so i think it's H7
RE: my ****!ng headlight went out...
ebay is a good place to start and go for the blues they are much brighter 80 or 100w
http://images.google.co.uk/imgres?im...l%3Den%26lr%3D
I doubt its a bigger problem, he probably either used cheap replacements, or more than likely touched the glass while installing them. If you touch the actual bulb part of the assembly, they will fail earlier than they rightfully should.
try www.luminicsbulbs.com, I had a pair of the Hyper Yellow's in my Integra for almost a yr w/out any problems, and the looked damn good too!
check out www.visionbulbs.com for replacements and at check out type in the code AUDIFORUMS for a %15 discount since they are an AF sponsor
My low beam is out . . . does that mean I have to buy the low beam h7 bulb?
I'm pretty sure that it's a H7 bulb... but to make sure here is a picture, the one that's out is the circular one, thanks guys
[IMG][/IMG]
[IMG][/IMG]
