is it my oxygen sensors?
Old May 16, 2006 | 02:18 AM
gotaudi's Avatar
Default is it my oxygen sensors?
hey guys My 1997 A4 1.8T is getting 13mpg in the city and 19 on the freeway. i logged the sensors and the pre cat sensor responded pretty good but the post cat seemed a little sluggish. From waht i hear is the pre cat sensor is the important sensor. so would the post cat sensor cause this much damage. thank you
Old May 16, 2006 | 11:23 AM
north5995's Avatar
Default RE: is it my oxygen sensors?
I don't think the post cat oxygen sensor does much. It wouldn't be messing with your gas milage. If anything you would want to replace your pre-cat.
Old May 16, 2006 | 12:57 PM
Slowb5's Avatar
basically all your second o2 sensor does is tell the ecu that your cat is doing its job.....( for those of us that have one ) so i dont imagine your o2 sensors would have to do w/ this, possibly an injector or maybe a spark plug.
Old May 16, 2006 | 01:17 PM
techbod's Avatar
cat problem, basically the first o2 sensor ( that's the one closest to the exhaust manifold ) is measure emissions the second one compares the results to inform the ECU of the cat performance,
when both o2 sensors reach a similar reading then this points to the cat being the problem rather than anything else, as your mileage is that low I would say the cat is bad
Old May 16, 2006 | 06:25 PM
gotaudi's Avatar
their is nothing wrong with the cat. I had the cat checked out. If i log the oxygen sensor what should they read? i am thinking of just changint the pre cat sensor because it does have over 100000 miles on it.
Old May 16, 2006 | 06:32 PM
north5995's Avatar
Just change the pre-cat sensor. I don't know if anyone knows what the exact readings should be, I sure as hell don't study every reading I get from my car especially from an emissions related device.
Depending on your engine code, the sensor could range from $40-240.
Old May 16, 2006 | 08:50 PM
Beer Mod's Avatar
Air filter or MAF or both.............
Old May 20, 2006 | 03:38 PM
dankhound's Avatar
front 02 should cycle above and below .45v. The post cat o2 should stay around.8v.
Old May 20, 2006 | 06:07 PM
T_REV_17's Avatar
like you, I too have a '97 A4 that had a similar problem...The MAF was the culprit this time...might wanna check it out...
Old May 20, 2006 | 11:20 PM
david9999's Avatar
Also, all the stations have now phased out MTBE as an additive and have started using 10% ethanol as an oxygenating agent. Most cars are experiencing a drop in MPG with the changeover.
brimhall99
Jun 22, 2008 03:03 PM
hartsoe1
Jan 28, 2008 09:06 PM
cabrioman1995
Jun 4, 2006 01:41 PM
gotaudi
May 16, 2006 02:58 AM
Samsafor
Feb 4, 2006 02:08 AM
