My Radio & My HID Kit...
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
Alright fellas I installed my H7 6000k kit, I got it from VisionBulbs here on this site, a few weeks ago and noticed something very strange. Over the last couple of weeks I noticed my radio has been really static'y. My local stations are just full of static. Well, I was driving yesterday and thought to myself, hey my radio isn't so static'y anymore.I then flipped on my headlights cause it was getting kind of dark and boom, my radio is full of static again. I was shocked. I turned my lights back off and boom, my radio was fine.
Why would installing an HID kit mess with my radio reception? I am totally baffled by this. Never in a million years would I thought that static would be caused by my HID headlights.
Thoughts? Suggestions?
I posted this in the VisionBulbs thread but thought a lot more people would see it here.
Sorry to drag this thread back up BUT....
I have installed my hid kit also from vision and i have loads of static on my radio when the hids are lit![Frown](https://www.audiforums.com/forum/images/smilies/frown.gif)
Did you fix the problem?
I spent another 45 mins moving my ballast but still have interference[:@]
Am i doomed to no reception on my radio now!
Oh yeah when i connected them first i got a check brakes display on the dash that cleared after i restarted the car...odd...
I'm guessing the ballasts are causing some kind of feedback through the ground of your radio... for starters, is the static only on radio or on radio AND cd?
If it's radio only... I got nothing for you.
If it's on both, I would buy 2 bosch 5 wire relays and run the power to the ballasts through the relay. I can diagram it for you if you wind up doing this, but i've solved a couple of ground induced feedback problems with high quality relay switching. - the fact that you got a random CEL after install points to an electrical gremlin.
Hope it helps.
Hope it helps.
a supressor will help, but a relay is better IMHO. I've used both with success. My vvme kit didn't come with relays. they are plug and play, but I cut the headlight harness and then soldered my connections to the relay using the factory headlight wiring as the swith to activate the relay.
keeps the strain off of the thin factory wiring, and also keeps any electrical noise out fo the factory harness.
Just went out and checked and its only the radio i get the static on and its clear on the cd.
It not noticable on the stronger stations only the weaker ones.
Guess i could wire the relay harness it came with to see if it helps,if not then i'll just have to live with it.
My abs light came on again but i think it only happens when i switch on the lights when the engine is at idle speed.will do more investigation on that.
I have that problem as well and it's really annoying!! Once I turn on my HIDs the radio goes to crap on most channels. Also, for some reason when I go south of my house on the highway the reception gets a lot better, which only frustrates me more because it leaves me with more questions! [:@]
