My thoughts on N75 Race Valve
Old Mar 11, 2006 | 03:06 AM
  #31
trailboss's Avatar
Default RE: My thoughts on N75 Race Valve
ORIGINAL: onepoint8tee
ORIGINAL: liquidxit2
sounds great, but Id be worried about burning up the stock turbo.
The stock turbo can boost 20psi all day long pretty reliably from what i understand... Im sure its not going to last as long as it would with stock ecu/n75 though.. I'll be happy when its k04 time anyway.
Do one or so hard pulls up to about 110, get out and look at your turbo. This is if you are chipped, stock boost levels im not sure if it will do it. Make sure its at night, makes you wonder how much longer will it last.
Old Mar 11, 2006 | 03:19 AM
  #32
onepoint8tee's Avatar
ORIGINAL: trailboss
yeah ive seen the glow. makes you realize how important the cool down is after driving. i wish i knew if it does that with stock boost levels.. Probably not... I mean the chip and n75 have pretty much trippled the stock boost on that puny thing. by the way... damn that n75 is so noticeable!!! Even my wife said its more fun to drive now... This valve has made it even more difficult to not speed.. O and i was on the highway last night and the power is just effortless at 70-80mph!!!! I barely need to press the gas down and its pulling nicely... Launches are so much better now too!!!!! Im gunna take a speedo video this weekend for fun.
Old Mar 11, 2006 | 04:05 AM
  #33
Slowb5's Avatar
Thanks badluckaudi....im ordering one on monday...so excited!!! what part number should i order?? 99 1.8T. im all smiles
Old Mar 11, 2006 | 06:15 AM
  #34
BadLuckAudi's Avatar
The turbo glows just as bright red when its not chipped and running stock levels, at night time you will almost always see the turbo glow at stock even if you wernt running it hard, its made to withstand alot of heat and isnt gunna eat **** at only 20psi
ORIGINAL: trailboss
Old Mar 11, 2006 | 06:39 PM
  #35
trailboss's Avatar
If you aren't running hard and your turbo glows on stock boost levels then something is wrong, clogged cat or something. And a k03 isn't made to flow 20psi and has a hard enough time flowing 15psi to redline.
Old Mar 12, 2006 | 02:38 AM
  #36
a4modrcin's Avatar
hey can you guys tell me will this part work on a 98 a4 1.8t the ecs page only list 99 and ups as applicable models but they also say if your car is not listed it the part will probably work does any one know befor i spend my money
Old Mar 12, 2006 | 02:44 AM
  #37
headshok2002's Avatar
The turbo will actually glow without driving it hard... I had the cruise set at about 70 mph (110~ km/h) for about 20 minutes... got off the highway, rolled into a gas station right off of the offramp... and popped the hood. Glowing like a **** :P
EDIT: Is the N75 something BT guys do? Is it necessary? Benificial?
Old Mar 12, 2006 | 06:12 AM
  #38
Slowb5's Avatar
n75 is for ko4 and ko3 i believe...and im sure it works on bt guys as well...but dont quote me....
Old Mar 12, 2006 | 06:20 AM
  #39
Bt guys dont need an n75 race valve cuz they use a mbc, so it determines the boost not the n75 so they just run the stock m75 so the comp thinks its there, its not nessicary to have but sure makes a difference the power it adds doesnt seem like much but you really do feel that extra 1-2psi of boost, its like re-chipping your car
Old Mar 12, 2006 | 04:34 PM
  #40
Dave666's Avatar
haha
