n75 race valve install
Old Jan 14, 2008 | 03:38 PM
B5TurboA4's Avatar
Default n75 race valve install
well my n75 came today and i went to install it.. i got the plug that goes in hooked up and the hose from the waste gate and the one to the turbo hooked up but whats the other outlet coming off the top of the valve supposed to be hooked too?
Old Jan 14, 2008 | 03:40 PM
cincyTT's Avatar
I'm make believe
Default RE: n75 race valve install
think you mean bottom, that goes into the intake.
Old Jan 14, 2008 | 04:04 PM
B5TurboA4's Avatar
haha my bad forget everything i just said. theres a short stem and a long stem coming off of the valve, just need to know which way one goes to the turbo hose and which one does not. the short one or long one.
Old Jan 14, 2008 | 04:08 PM
cincyTT's Avatar
I'm make believe
short is the intake.
Old Jan 14, 2008 | 04:22 PM
Papachristou's Avatar
do you have a chip at all or just the race valve? some chipped b6's have had problems with the race valve, i thought about trying it...let us know it works!
Old Jan 14, 2008 | 04:38 PM
B5TurboA4's Avatar
got it all hooked up correctly i believe. not feeling much difference tho, increased throttle response a little thats about it. Anybody know if they motor takes some getting used to or are they suppose to function 100% right away?
Old Jan 14, 2008 | 04:42 PM
B5TurboA4's Avatar
and nope, no chip
Old Jan 14, 2008 | 06:06 PM
chaos92287's Avatar
ORIGINAL: cincyTT
no, if you do that you will run unlimited boost (till you blow your tb hose off). the long one goes into the TIP, the one opposite from it goes to the wg, and the other one goes to the banjo bolt
i have a whole DIY written up for my boost controller, that includes this info, but some stupid girl back home has my digital camera and all the pics on it[:@]
Old Jan 14, 2008 | 06:11 PM
chaos92287's Avatar
ORIGINAL: B5TurboA4
it should work as soon as you install it. do you have a boost gauge? it doesn't increase boost that much so you wont feel that much of a difference. especially since your not chipped. at least spend the 150 for the speedtuning one.
Old Jan 14, 2008 | 09:39 PM
turbo kraut's Avatar
Tech Guru
it is supposed to raise boost 2 psi..... no gains really
