n75 valve good ?
Old Dec 16, 2007 | 05:58 PM
ocielz's Avatar
Default n75 valve good ?
i did some searching but i cant find the answer, i have a 2001 a4 1.8t q. that is chipped, and i need to know if the n75 valve is worth it on my car and if so where can i get it? i read that you can get it in at the dealer, True?
Old Dec 16, 2007 | 06:00 PM
cincyTT's Avatar
I'm make believe
Default RE: n75 valve good ?
the car already has a n75 on it. people often waste $70 or so on changing it to one of the dirrent versions for a mere 2-3psi. A mbc would be a better alternative
Old Dec 16, 2007 | 06:07 PM
ocielz's Avatar
mbc maybe later on with bt, but whatabout now with k03 i mean 2-3 psi is still something, right?
Old Dec 16, 2007 | 06:11 PM
onepoint8tee's Avatar
You can get a decent mbc for the same costas an N75 and accomplish the same thing. Just dont be a douche by cranking the boost much past chipped levels, of course it wouldnt matter anyways since you have a map sensor to save you if you do.
Old Dec 16, 2007 | 06:58 PM
cincyTT's Avatar
I'm make believe
people push ko4-15's to beyond reason, why not do the same with basically the same turbo? [8D] But really, you have much more benifits with a mbc than a n75.
elduderino200
Jul 8, 2015 03:35 PM
copper07
Mar 14, 2012 12:35 AM
Baby Kito
Jun 1, 2010 11:05 PM
GraffixWB
Dec 13, 2005 07:03 PM
