Name that car part.
I am pretty sure this is my fuel filter though I am not sure.
This is under the car near gas tank.... rear passenger side of the car. Also is it very hard to change.... my car has 115+k miles on it and I'm not sure the last time this was changed. I know how to change the oil and what not so that is around my skill level. [IMG]local://upfiles/19390/C54713D3C4164584B6DE23BC36098E42.jpg[/IMG] |
RE: Name that car part.
Fuel filter - $15-20 at your local parts place. Takes about an hour to change... I had to cut the strap around it.
Bullshit that the fuel filter - thats the factory NOS system
;) - make sure you get new washers when you replace it. |
Yeah I went to replace that and couldn't get the thing out!!! I couldn't loosen up the clamp that holds it in. How do you do that???
Josh |
Plastic explosives!
Here is DIY http://www.audiworld.com/tech/eng49.shtml
My wix filter came with new crush washers.
Just cut the plastic clamp around it and use a zip tie. You also have to drop the tank slightly. |
The B5 design is crap compared to the B6, took me 5 min and other people with B5 take about an hour.
Most def. your fuel filter... It filters your fuel;)
fuel filter it is so use a spanner to lock the inner as pointed out the release the bolt
[IMG]local://upfiles/12092/CF640E53C4514E44BA4666F310709823.jpg[/IMG] |
