necessary mods?
Old Aug 20, 2007 | 10:38 AM
Grk_A4's Avatar
Default necessary mods?
I just bought a 2007 a4 2.0tq. I am currently leaning toward buying the apr chip for it. I was wondering if the chip would give me the performance that apr has listed on their site without any supporting mods. Is there any mod that I need to go with the chip. For example exhaust, intake, etc. I understand that it will probably perform better with an exhaust, but I was wondering if any of these mods were necessary to achieve the numbers posted on apr's site.( 241hp and 292lb-tq at 93 octane).
Old Aug 20, 2007 | 10:41 AM
cincyTT's Avatar
I'm make believe
Default RE: necessary mods?
Should be rather close to what is posted with just a chip.
Old Aug 20, 2007 | 10:43 AM
ironman's Avatar
all the mods will help power wise but the only necessary upgarde will be the DV im not fam with teh 2.0 DV but upgraqding is never a bad idea, search for what ppl are using with teh newer B7's and you should be good
Old Aug 20, 2007 | 12:06 PM
Grk_A4's Avatar
I figure I will go with the apr chip and buy their r1 DV. Thanks for all your help fellas
Old Aug 20, 2007 | 02:06 PM
cincyTT's Avatar
I'm make believe
mjmautohaus sells the r1 for the cheapest i have seen.
Old Aug 20, 2007 | 02:17 PM
onepoint8tee's Avatar
An R1 wont work in a B7. The stock DV is fine for a chip, but there is an upgrade.
Your dv is electronicaly controlled and looks totally different.
http://www.ecstuning.com/stage/edpd/...ategory=Engine
Old Aug 20, 2007 | 02:23 PM
cincyTT's Avatar
I'm make believe
forgot about him having a 2.0T. Forge makes a dv that can go 100% dv or bovor even 50/50 for the 2.0T's
Old Aug 20, 2007 | 02:34 PM
ORIGINAL: cincyTT
Forge just makes the spacer for the 2.0t fsi dv. Its not an actual dv/bov/bpv. Or are you talking about somethinig different?
Old Aug 20, 2007 | 02:45 PM
cincyTT's Avatar
I'm make believe
I is....
A switchable valve for the VAG 2.0 litre FSi Turbo engine which allows a choice of Blow off (loud) / Blow off and partial recirculation (intermediate) or total recirculation (quiet). This gives you the choice of exactly how loud you wish your valve to be . Please note the adjustable Blow Off Valve valve is not suitable for the Audi A4 due to clearance issues - please use the FMDVFSiT for these vehicles.
$180 form 20squared.com
Old Aug 20, 2007 | 02:46 PM
cincyTT's Avatar
I'm make believe
Crap just saw the part about clearence issues.... Ooopps Wonder if that can be fixed to fit the valve.
