Need advice on buying an 96 A4
Old Aug 15, 2005 | 01:58 AM
mander's Avatar
Default Need advice on buying an 96 A4
Hi I have been wanting to get an A4 for a long time and finally found a possible match. The car is a 96, 2.8 Liter V6 and has about 129k on it. Its in great shape , awd but no leather. All in all he's asking about 400 under blue book or 6500. Im pretty sure its a good deal , I have done some searching but can anyone give me a few thoughts on what major mantenince might need to happen around this mileage.
Thanks and happy to have found this forum!!
Old Aug 15, 2005 | 02:43 AM
Dave666's Avatar
Default RE: Need advice on buying an 96 A4
Im not 100% sure.
But that price seems a bit high for a 96 with 129k
Old Aug 15, 2005 | 02:47 AM
BFlan2001's Avatar
depending on where you live and what condition it's in, that might be a good deal....ask the seller when the first timing belt change was done...the second one should probably be due about now (every 60-70k miles)...it's very strange that they aren't leather seats, i thought leather was the only option available in 96...things to watch out for when you test drive it:
ORIGINAL: bentframe
make sure the suspension is good....worn control arms will squeak, tie rod ends will clunk when you hit bumps, cv joints will click during low speed turns (if you're on the gas), open up the oil cap to look for signs of oil sludge (this is especially important with the 1.8Ts)...do the same for the power steering fluid, as well as the coolant. sometimes people top them off or refill them with regular fluids and that can cause big problems including sludge issues....test the cruise control, the switches are known to fail (typically it's an easy fix, a good way to knock a few bucks off the price ). make sure the sunroof is fully functional as well as windows (check each door's switch individually)..listen on the freeway for a humming/grinding sound for failing wheel bearings..oh, and leave the radio OFF during the test drive, test the speakers before or after driving....also consider the mileage on the timing belt, they need to be done every 60-90k miles....search the forums, there are TONS of threads on all this stuff...
Old Aug 15, 2005 | 06:39 PM
audispeeddemon's Avatar
get a 1.8T. I got mine for 6700 with 105000 on it and all the maintence done on it. If i were u i would keep looking dont settle!!!
Old Aug 15, 2005 | 07:07 PM
headshok2002's Avatar
the 12v v6 is reliable as hell though... so it has its strengths.
Old Aug 15, 2005 | 09:40 PM
Jestnomen's Avatar
6th Gear
That is kinda high. I've seen them going for almost a grand less than your price.
Old Aug 16, 2005 | 09:00 PM
MadIce's Avatar
I just bought a 97 2.8l a few months back for $6k with 97,000. Was in very good condition.
Old Aug 16, 2005 | 10:54 PM
Sichko's Avatar
i bought my 96 12v with 100k miles on it for 6,500, got it down from 7,500 cause i payed in cash, u could probably get a little lower of a preice but... u never know. As far as repairs go my car has been good only problem was that the left and right engines mounts broke ($400 to replace)
Old Aug 16, 2005 | 10:56 PM
Sichko's Avatar
^^ madice, r 97 30v or still 12v?
Old Aug 17, 2005 | 01:55 AM
BFlan2001's Avatar
ORIGINAL: Sichko
97s are 12Vs
