need expert advice -what can this be?
Old May 20, 2006 | 01:11 AM
BadLuckAudi's Avatar
Default RE: need expert advice -what can this be?
yea it could cuz ther mani would heat up and it can close off the leak, our 200 does it all the damn time, higher rpms sounds just find but a funky noise at idle and just above
ORIGINAL: quiktsi
If it was an exhaust leak it would not go away at higher rpms.
Old May 21, 2006 | 12:41 AM
acetrebo's Avatar
Anyone out there......
how can I tell if my valves are f-d up?
Thanks!
Old May 21, 2006 | 01:40 AM
you would have to take your head off
ORIGINAL: acetrebo
What do you guys think?
Do the timing belt and check the camshaft position sensor and hope for the best?
How can I tell if there is valve damage?
Old May 21, 2006 | 01:51 AM
BaconBait's Avatar
ORIGINAL: acetrebo
Thanks!
Compression test.
Old May 21, 2006 | 02:56 AM
Audia421's Avatar
i had same problem Water Pump and Timing belt
Old May 21, 2006 | 09:55 AM
david9999's Avatar
I doubt your valves are f'd. You car would be unlikely to run.
Noises are hard to diagnose over the internet. If you can't figure it out when you are listening to your car, it is hard for us to figure out just reading words.
Do a compression test, do your timing belt and water pump as it is time. Try to figure out where the noise is coming from.
Old May 21, 2006 | 01:02 PM
CRAZYHAWK's Avatar
Replace the tensioner and damper pulley.
Old May 22, 2006 | 02:09 AM
  #18
luvin_the_rings's Avatar
i would just do a full timing belt job, 87k is pretty high for a tb job..
bently says do it every 90k
while your at it replace the camshaft sensor
my .02...
Old May 22, 2006 | 06:19 PM
  #19
acetrebo's Avatar
Thanks guys, I really appreciate the re-assurance.
The engine does still run.
I am going to do timing belt kit (water pump, all accessory belts), and the Camshaft position sensor.
I will let you all know the outcome. I am shooting for wednesday to have it done.
Any tips on timing belt job? I have read the write-up on audiworld, it think I can handle it OK. Just looking for any tips that may not be in the writeup that may help me do the job.
What in your experience would have helped had you known about it at the start of the t-belt job?
Thanks!
Old Jun 2, 2006 | 12:17 PM
  #20
truckjunky87's Avatar
So ... did the timing belt and waterpump fix your noise?
