need to find out what piping i should go with
MANIFOLD - STAINLESS 1.8L T3/T4
TURBO BRAND NEW IN THE BOX W/ WARRANTY
T3/T4 FLANGE .70 HOT SUPER SPOOL
38mm WG BRAND NEW
RFL BLOW OFF VALVE - BRAND NEW
GASKETS
FLANGE FOR BOV
FLANGE KIT FOR WASTEGATE
TURBO ACCESSORIES !!
INTERCOOLER
MANIFOLD INFO:
This manifold is drag-race quality, and similarly design manifolds can be found on professional drag cars.
Manifold has flange for an external wastegate. And since this manifold is tubular steel, it flows better than cheap cast iron
and is less prone to cracking. It was custom-made to be used with A 2 BOLT external wastegate.
TURBO INFO:
T3 TURBO INFO AUDI T4OE TURBO
3" INLET DIAMETER
3 V-BAND" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
.50 A/R .70 HOT
57 TRIM
SPECS:
STAGE IV WHEEL
BALANCED AND BLUEPRINTED AND COMPRESSION TESTED
$200 for this kit
THIS IS BRAND NEW 2.5" Universal INTERCOOLR piping. Light weight Polished Aluminum intercooler piping, 2.5"=LOW TURBO LAG
Kit including:
2x 90 Degree Mandrel bend
2x 45 Degree Mandrel bend
2x 180 Degree U bent Mandrel pipe
2x straight pipe
8x 2.5" 3 polyester reinforced High temperature silicone hose.
16x 2.5-2.75" T-Bolt Clamp best for turbo application.
All Piping are 24" long. Pipe thickness:2mm.Pressure Rating: 35PSI
Temperature Rating:-65F to 350F
88 for this 1
[ul][*]100% Brand New in box [*]Universal fit all cars with turbo system or DIY turbo system [*]Chrome coated 2.5" Intercooler Piping w/ Silicone Hose. [*]Made out of high quality of 6061 Aluminum chrome coated finished. [*]Extra thick Piping 1/16 Inches. [*]Package included:
* 8 x Piping
- 2 x Straight Pipe
- 2 x 45 Degree Pipe
- 2 x 75 Degree Pipe
- 2 x 90 Degree Pipe.
* 16 x T-bolt clamps
* 6 x Silicon Couplers
* 2 x Silicon Elbow Couplers [*]Increase 40-60% air flow when compare with other piping. [*]Professional installation is highly recommended. [*]The perfect kit for the DIY or professional builder. [*]Exactly same as picture [/ul]
145 for this 1
Mandrel-bent Aluminum Polished 3" pipes
2 Pieces - 90 Degrees Mandrel-bent Pipes
2 Pieces - 75 Degrees Mandrel-bent Pipes
2 Pieces - 45 Degrees Mandrel-bent Pipes
2 Pieces - Straight Mandrel-bent Pipes
8 Pieces - Racing Blue Straight Couplers
2 Pieces - Racing Blue 90 Degree Elbows Couplers
16 Pieces - Clamps
Specification/Performance:
This ultimate unversial Intercooler Pipe Upgrade Kites increase efficiency & performance over the factory intercooler pipe system by offering up to 45% increase air flow.
These pipes are 1/16" thickness, total length of 18", and made by most advance, high quality 6061 Aluminum
