need help
Yes this has been done and it is a direct fit.
Couple of problems with it though. It turns itself off after an hour and there are backlight problems. This is because your car does not have a Canbus wire. There is a fix though, if you don't mind a little soldering:
http://www.audiworld.com/tech/elec86.shtml
Does this fix solve the shut down problem as well or just the back light? if no, is there a fix for the shut down problem?
ORIGINAL: Jestnomen
