NEED HELP!!!
Old Nov 21, 2006 | 07:53 PM
BPMagoo's Avatar
Default NEED HELP!!!
im new here and i needed some help...... I drive a 98 A4 ive been having problems with my engine. It seems that it overheats easily and then it starts to smoke out of my cat........... any suggestions on what i should do
Old Nov 21, 2006 | 08:04 PM
LabattZ's Avatar
Default RE: NEED HELP!!!
Are you mechanically inclined?
If so, further diagnose - find out what all your symptoms are and provide more information
If not, take it to a mechanic.
Old Nov 22, 2006 | 05:12 PM
acetrebo's Avatar
What have you checked so far?
Old Nov 22, 2006 | 05:16 PM
techbod's Avatar
more information required, white smoke is normal for a catalyst the over heating is a main issue
new2me's Avatar
Are fans working?
Is the coolent circulating?
Has the water pump been changed? (My $$ is on this as the problem)
Old Aug 27, 2008 | 10:02 PM
BPMagoo's Avatar
water pump hasnt been changed....had some engine work one it but still nothing...lately the lost almost all power...fans work...coolent does circulate...
frined said might be warped head..maybe even shut trubo..
