Need help!
Old Apr 1, 2007 | 08:49 AM
Sleveke's Avatar
Default Need help!
Today I wascleaning the engine bay of my audi a4 b6 and found some leaks.
Anyone know what this could be and what I need to fix it.
Thanks.
[IMG]local://upfiles/32909/A350D25B37F1466895E400E4B3AF4B9E.jpg[/IMG]
Old Apr 1, 2007 | 09:38 AM
x1rider's Avatar
Default RE: Need help!
Not 100% clear on what I'm seeing on the picture but it looks like a pink crusting. If you are running G12 engine coolant, pink crust on the engine = dried engine coolant. Probably a coolant leak.
Old Apr 1, 2007 | 09:41 AM
x1rider's Avatar
I magnified the pic, it looks like the insert for the engine coolant temperature sensor by the firewall is leaking, you can see an accumulation of pink crusting right on the vertical hose, by the clamp. Now I'm pretty sure, engine coolant leak.
Old Apr 2, 2007 | 04:17 AM
Sleveke's Avatar
Hi x1rider,
thanks for your quick response, is this very serious?
Old Apr 2, 2007 | 08:41 AM
x1rider's Avatar
If you don't have time to fix it right away, keep an eye on your engine coolant level in the expansion tank, make sure it stays high enough. I would fix it as soon as possible though.
