NEED HELP INSTALLING CD DECK!!(rear speakers)
Old May 5, 2005 | 11:02 PM
AudiA4Buysta's Avatar
Default NEED HELP INSTALLING CD DECK!!(rear speakers)
Hey,
Im trying to put a Pioneer cd deck into my 97 Audi A4 1.8T....I already bought a wiring harness, the tweeters, fronts and cd players works fine. I hear the rear speakers require additional wiring cutting etc. b/c they are on their own amplifier....could somebody please explain exactly what i must cut and wire for my rear speakers!?!?!?
Thanks alot!!
Tim
Old May 5, 2005 | 11:16 PM
headshok2002's Avatar
Default RE: NEED HELP INSTALLING CD DECK!!(rear speakers)
Hmm, there is a way, though im not sure how... easiest way might be to run fresh wire from your deck, to your rear speakers. just pull up the door sills, and you're pretty much there... it isnt too hard -- easier to go back to stock that way, too.
Old May 6, 2005 | 01:07 AM
black991.8tq's Avatar
the rear speakers are somthing weird like 3 ohm what u need to do is remove them and put new ones in there then just run the speaker wire to the new speakers fronm the radio
Old Mar 9, 2007 | 12:56 AM
secmil's Avatar
Sorry to dig up an old thread, but I ran into the same problem tonight. Does anybody know the correct way to wire the stock speakers to a new head unit? I know it's possible, and at the moment I don't have the time/money to re-wire and get new rear speakers (which I would rather do anyway. It's non-bose '98, was a Delta radio. Any help would be greatly appreciated!
Old Mar 9, 2007 | 01:35 AM
99A4NOW's Avatar
If the rear speakers are amplified you could try hooking the rear outputs from the radio to the wiring harness adapter I'm hoping you bought. Then try hooking up the remote turn on (power ant-possibly the blue wire), this should turn the amps on and make the rear speakers play.
Old Mar 9, 2007 | 12:24 PM
secmil's Avatar
Yeah, i figured it out... The problem is that the wiring harness adapter includes the rear speaker outputs, but the plug on the car end does not. It's an amplified common ground system only for the rear speakers, which makes it really really confusing, but all you have to do is buy a PAC OEM-2 (which I already had, thankfully) and on the input end go green wire to green wire, green and black, violet and violet and black (color for color, no other wires are needed here) from the new radio, then I forget the output wire colors, but I'll take pictures when I hook it all up after work today and write a quick how-to.
It's easier and quicker than replacing speakers and running all-new wires, which is sweet cause I need it for a trip tomorow, but you still have to find a place for the OEM-2 unit (any suggestions other than the glove box? It's like 2x4x1 inches I think...)
Old Mar 9, 2007 | 01:08 PM
techbod's Avatar
Radio Systems[/align]Structure of radio systems (vehicles up to model year 1997)[/align]
"Beta" radio system (Saloon)
1 -→ Rear window aerial with aerial amplifier
2 -Mid-range/treble loudspeaker (installed in front upper door trim)
3 -Bass loudspeaker installed in front lower door trim [/ul]
"Beta" radio system (Avant)
1 -→ Roof aerial with amplifier
Assignment of contacts for multipin connectors I, II and III on the rear of the radio
Note:
Connector contacts not listed have not been assigned.
→ Multi-pin connector II, 8-pin, brown
3 -Loudspeaker (+), front right
4 -Loudspeaker (-), front right
5 -Loudspeaker (+), front left
6 -Loudspeaker (-), front left [/ul]
Multi-pin connector III, 8-pin, black
2 -AF mute (telephone system)
3 -Battery + (terminal 30)
4 -Terminal 86s - connection for switching on and off via ignition key (S contact)
5 -Control positive for aerial amplifier
6 -Illumination (terminal 58d)
7 -Battery + (terminal 30)
8 -Earth (terminal 31) [/ul]
"Gamma" radio system (Saloon)
4 -Wide-band loudspeaker (active, with twin amplifier), at rear left in rear shelf
5 -Wide-band loudspeaker (passive), at rear right in rear shelf [/ul]
"Gamma" radio system (Avant)
4 -Wide-band loudspeaker installed in rear door trim
5 -Bass loudspeaker (subwoofer) installed in rear left of luggage compartment under side trim [/ul]
Note:
→ Multi-pin connector I, 20-pin
1 -Line out, rear left
2 -Line out, rear right
3 -AF earth
4 -Line out, front left
5 -Line out, front right
6 -Positive switched (active loudspeaker)
7 -BOSE identification
8 -Clock signal
9 -Data signal
10 -Enable signal
11 -Steering wheel remote control
12 -Air conditioner (planned) [/ul]
→ Multi-pin connector III, 8-pin, black
1 -Gala (speed signal)
"Delta" radio system (Saloon)
2 -Bass loudspeaker installed in front lower door trim
3 -Mid-range/treble loudspeaker (installed in front upper door trim)
4 -Wide-band loudspeaker (active, with twin amplifier), installed at rear left in rear shelf
5 -Wide-band loudspeaker (passive) installed at rear right in rear shelf
6 -CD changer (optional) installed in rear left of luggage compartment [/ul]
"Delta" radio system (Avant)
Note:
3 -AF earth
8 -Clock signal
9 -Data signal
10 -Enable signal [/ul]
11 -→ Steering wheel remote control
12 -USA codes
13 -CD bus data (CD changer)
14 -CD bus clock (CD changer)
15 -Earth (CD changer)
16 -Permanent positive (CD changer)
17 -CD switched positive (CD changer)
18 -CD AF earth (CD changer)
19 -Signal wire for left channel (CD AF L)
20 -Signal wire for right channel (CD AF R) [/ul]
"Delta radio system with BOSE sound system"
(Saloon)
2 -BOSE power amplifier installed in rear left of luggage compartment
4 -Mid-range/treble loudspeaker (installed in front upper door trim)
5 -Wide-band loudspeaker installed in rear door trim
6 -Bass loudspeaker installed in rear shelf
7 -CD changer (optional) installed in rear left of luggage compartment [/ul]
"Delta radio system with BOSE sound system" (Avant)
2 -BOSE power amplifier, combined with bass loudspeaker (subwoofer), installed in rear left of luggage compartment under side trim.
5 -Wide-band loudspeaker (2-way) installed in rear door trim
Note:
3 -AF earth
6 -Positive switched (BOSE power amplifier)
8 -Clock signal
9 -Data signal
12 -USA codes
[IMG]local://upfiles/12092/C29C8F5FFF6D4CD3807062A88AFB369D.jpg[/IMG]
[IMG]local://upfiles/12092/E7C9D6E275CA4F9681F0F2FBF325E274.jpg[/IMG]
[IMG]local://upfiles/12092/3BBCD41858D84159A484B024D23B96DA.jpg[/IMG]
[IMG]local://upfiles/12092/077D8BB46AA7459E91DF5EE89703CB4B.jpg[/IMG]
Old Mar 9, 2007 | 07:26 PM
PKSJeter's Avatar
So here's a question (i just installed a new stereo and my back speakers dont work). Since I bought new speakers for the back, does that mean i have to rewire? If i did rewire would i still need the PAC OEM-2?( i bought a wiring harness from BestBuy and thenew stereo works as do the front speakers... just not the back speakers.)
Old Mar 14, 2007 | 12:42 AM
secmil's Avatar
If you rewire, you won't need the PAC OEM-2, and with new speakers you'll probably need to re-wire...
However, For anybody looking for help with the OEM-2, the correct way to wire only the rear speakers with a new head (replacing a Delta) with non-bose speakers would be:
(On the OEM-2, the INPUT side is the side without the RCA cables...)
Head unit GREEN wire ---> OEM-2 GREEN wire INPUT
Head unit GREEN/BLACK wire ---> OEM-2 GREEN/BLACK wire INPUT
Head unit VIOLET ---> OEM-2 VIOLET wire INPUT
Head unit VIOLET/BLACK ---> OEM-2 VIOLET/BLACK wire INPUT
IF your NEW head unit has a REMOTE amp wire (usually BLUE or BLUE/WHITE), THEN:
Head unit BLUE (or BLUE/WHITE or REMOTE) ---> WHITE wire from the yellow connector in the dash
If your new head unit does not have a remote amp turn on, I'm not sure what you'll have to do for sure, but if you hook up the
OEM-2 BLUE/WHITE wire OUTPUT ---> WHITE wire from the yellow connector in the dash
AND
Have 0.8v hit the OEM-2 BLUE/WHITE wite INPUT when the car is running (ACC wire?)
It may work (DIDN'T TRY IT MYSELF!!!!)
For the OEM-2 OUTPUT (the end with the thicker RCA cables), then...
OEM-2 GREEN wire OUTPUT ---> BLUE/GREEN wire from the yellow connector in the dash
BOTH OEM-2 GREEN/BLACK wire AND OEM-2 VIOLET/BLACK wire OUTPUTS ---> BOTH BROWN/RED wires from the yellow connector in the dash
OEM-2 VIOLET wire OUTPUT ---> BLUE/RED wire from the yellow connector in the dash
Aaaaaand, that's it!
Now you get to force all of those wires and components into that tiny space behind the head unit and hope you did it all right! For me as soon as the OEM-2 was hooked up everything worked beautifully!
Old Mar 22, 2007 | 04:49 AM
sdsteez's Avatar
bump
new deck = need to be rewired straight to deck and ill be cool?
