Need help with my 97 A4
Old Sep 7, 2005 | 05:00 PM
ShayA4's Avatar
Default Need help with my 97 A4
I just got my 97 A4 about 3 months ago....Not that long ago my check engine light came on but went back off a couple days later..but now it drags in the rpms...Could it be a sensor goin...this is my first Audi so i need some help..
Old Sep 7, 2005 | 05:17 PM
jaustin's Avatar
Member
Default RE: Need help with my 97 A4
could you be a little more specific?
Old Sep 7, 2005 | 05:25 PM
ShayA4's Avatar
Well first off the car is auto..when i went up hill it would hold the gear longer i guess you could say.. now i does it even if it's a small incline..but other times it drives perfectly fine... I did have it into to Audi dealer for a new ignition and new upper control arms and tie rods just 3 days before it started to do all this... someone i know said it could be the O2 sensor goin..but i thought i would get other peoples advice.
Old Sep 7, 2005 | 06:07 PM
InsaneHatter's Avatar
1st off can you please tell us if its a 1.8T or 2.8?
Old Sep 7, 2005 | 06:10 PM
ShayA4's Avatar
I am sorry it's a 1.8t.
Old Sep 7, 2005 | 06:14 PM
Try to find someone with a VAG-COM to pull some codes... if your CEL came on your might have a code stored. May be too lean because of a vaccum leak... or bad O2 sensor...
Have you done a tune up recently???
Oil change? Air Filter? Spark Plugs? All Fluids (not the cause but good to do)
I would think it to be a vaccum leak or a bad 02 sensor
Old Sep 7, 2005 | 06:23 PM
ShayA4's Avatar
I did an oil change on it soon after i got it..I didn't do any of the other things when it was at the dealer i had them check everything over...But i will check everything over again and maybe change the plug and airfilter to be on the safe side...now if it is a vacuum leak how much is that to fix and an O2 sensor too.
