need help with my car
Old Apr 12, 2007 | 10:51 AM
rafa_207's Avatar
Default need help with my car
took my car to autozone and check for codes and it gave me a bad o2 sensor do you guys think thats why the car is missfiring when I steep on the gas and also is runing rich and when Im acelrating the boost goes up and down is these a boost leak or can it be because of the o2 sensor because thats the only code im getting thanx....
Old Apr 12, 2007 | 11:08 AM
CRAZYHAWK's Avatar
Default RE: need help with my car
Post the code.
Old Apr 12, 2007 | 04:46 PM
FASTER's Avatar
Tech Slut
u say it misfiring... but it didnt throw a misfire code also?
Old Apr 12, 2007 | 08:16 PM
acetrebo's Avatar
Maybe he means backfiring rather than misfiring, possibly due to the bad o2?
Old Apr 13, 2007 | 03:16 AM
khj677turbo's Avatar
Hey rafa, i dunno if its you from cardomain, w/e but my car backfires as well, im going to autozone soon to get it checked. I think its my cat thats causing the problems, but everyone on here think my car is misfiring and throwing codes. Ill let you know.
Old Apr 13, 2007 | 03:44 AM
onepoint8tee's Avatar
A bad02 sensor wont cause a misfire, but a misfire will cause an 02 sensor code to come up due to unburntfuel/gases passing intoand "shocking" the cat. If the engine is misfiring, you should have fault codes strored for which cylinder it is happening on. If you get a cyl.2 misfire code, swap the coil pack with cyl.3 and see if the misfire fault code follows the coil pack. If it does, get a new coil pack. A boost leak can cause you to run rich and misfire. But getting the misfire fault codes and swapping coil packs is sometimes easier than trying to find a boost leak. Sooooo... DO you have specific cylinder misfire codes or not?
EDIT
Just went and looked at your other thread: https://www.audiforums.com/m_475932/.../tm.htm#476099
So you replaced the coil pack(s)?
If you have a pre 2000 1.8t, Im willing to bet $20 that your ICM is bad. (Located ontop of the aribox) Its very common to get a cyl. 2 misfire when that thing goes bad.
Old Apr 19, 2007 | 10:51 AM
rafa_207's Avatar
ok so what I did is I changed the o2 sensor before the cat and erased the codes I driven the car for three days and the check engine light does not turn on anymore but still when I steep on the gas more than half way down or down shift and step on it which is when the turbo begins to work harder I get the jumping and sputter and backfires I really dont know what to do next plz someone help me ....
Old Apr 19, 2007 | 10:52 AM
rafa_207's Avatar
and no I dont have any cylinder missfire codes or nothing evrithing is clear....
Old Apr 19, 2007 | 11:05 AM
rafa_207's Avatar
also I dont have a catalitic converter just a 3 inch pipe all the way backcould these be the problem ?
Old Apr 19, 2007 | 01:39 PM
CRAZYHAWK's Avatar
Check for hidden codes, codes without a CEL.
