NEED HELP WITH THIS OBD P0299
A4--- 72,000 MILES AND THIS CODE CAME UP. ANY THOUGHTS OF WHAT THIS COULD BE AND HOW TO FIX?
THANKS |
RE: NEED HELP WITH THIS OBD P0299
I dont see that code in my dtc chart. What was the description?
Confirmed, i don't have that fault code in my chart either. You must have read it incorrectly.
I don't know if you still have this issue, but I just recently got that CEL code as well. It's "under boost" code and you are loosing boost pressure somewhere between the turbo and the throttle body. Components like the DV or MAP sensor could be damaged or needs cleaning. Check the piping and make sure they are on tight. Other than that, I don't know what else could be the issue.
