NEED HELP WITH THIS OBD P0299
Old Feb 4, 2008 | 05:02 PM
JRUPPERT1957's Avatar
Default NEED HELP WITH THIS OBD P0299
A4--- 72,000 MILES AND THIS CODE CAME UP. ANY THOUGHTS OF WHAT THIS COULD BE AND HOW TO FIX?
THANKS
Old Feb 5, 2008 | 10:53 PM
dankhound's Avatar
Default RE: NEED HELP WITH THIS OBD P0299
I dont see that code in my dtc chart. What was the description?
Old Feb 5, 2008 | 11:20 PM
auditech79's Avatar
Confirmed, i don't have that fault code in my chart either. You must have read it incorrectly.
Old Aug 21, 2008 | 10:29 AM
dextrek's Avatar
I don't know if you still have this issue, but I just recently got that CEL code as well. It's "under boost" code and you are loosing boost pressure somewhere between the turbo and the throttle body. Components like the DV or MAP sensor could be damaged or needs cleaning. Check the piping and make sure they are on tight. Other than that, I don't know what else could be the issue.
sycklylow
Apr 12, 2025 02:00 PM
Dr. Drivability
Jan 16, 2016 07:15 PM
prasamin
Jun 2, 2012 08:27 PM
23david23
B7 Models
Jan 26, 2011 08:29 AM
myblueaudia4
May 28, 2010 01:08 PM
