need help please
I am new to the forum. I got a chk engine sign today, so I went to autozone to chk it out. The code was P1136. Which is fan circuit malfunction. what exactly is this? Does this need urgent attention (can i live with this). If not how much I'll be spending?
Actually P1136 is system too lean, not too rich.
Check for vacuum hose leak, intake leak. Failing that may need Mass flow sensor (MAF).
Could also be clogged injectors. Run some fuel injector cleaner and look for vacuum leak. If niether help, replace the MAF.
search the archives.
Diagnostic Trouble Code (DTC)
Malfunction text
MIL
Corrective action
SAE
VAG
P1136
17544
Long Term Fuel Trim Add. Fuel, Bank1
System too Lean 2)
2 Dcy
- Check intake air system for leaks ("false air") Page 24-97
- Check HO2S -G39- and O2S control Page 24-17
- Check Mass Air Flow (MAF) sensor -G70- Page 24-57
- Check fuel pressure regulator and residual fuel pressure Page 24-93
- Check fuel injectors Page 24-87
- Output Diagnostic Test Mode (DTM) Page 01-42
Malfunction text
MIL
Corrective action
SAE
VAG
P1136
17544
System too Lean 2)
2 Dcy
