Need help from someone with Bentley manual
Old May 16, 2007 | 01:32 PM
99A4NOW's Avatar
Default Need help from someone with Bentley manual
My coolant temp sensor appears to be bad. I'm trying to determine if it is actually the sensor or the gauge (gauge reads cold even though the engine is hot and oil temp is around 200*) It looks like this and it is mounted in the flange on the back of the cylinder head:
I think I need the resistance value between pins 1 & 3 and 2 & 4. Any help would be greatly appreciated.
BTW, today is the second day I've had no temp reading but only got a CEL today- may have been because I unplugged it while I had the key on....
Thanks for you help!
Old May 16, 2007 | 01:36 PM
CRAZYHAWK's Avatar
Default RE: Need help from someone with Bentley manual
The temperature sensor needs replacing.
Old May 16, 2007 | 01:37 PM
techbod's Avatar
[IMG]local://upfiles/12092/DB8649D4F57648A3A73B543C1C9B58B3.jpg[/IMG]
Old May 16, 2007 | 02:35 PM
acetrebo's Avatar
I love you Dave.
Non-romanticlove, of course, but man you are great!
Old May 16, 2007 | 03:53 PM
99A4NOW's Avatar
That's awsome! I'm guessing I have Dave to thank. I'm going to have to go back and check but I think I've got those readings on pin 1&3. Pretty close anyway. But I guess I'm wondering if there is anything about what the values should be on pin 2&4 which I think are for the gauge. If the measurements are correct then I suppose I have a faulty gauge or wiring to it? Wierd that it worked ever since I've owned the car, then after repalcing the coolant and some hoses it worked great for two days then takes a crap.
Does the maunal say anything about what kind of voltage/ground should be on the wires going to the sensor?
Thanks again for all you help! If I didn't have to keep spending my money on parts I'd be able to afford that manual...
Old May 16, 2007 | 09:13 PM
99A4NOW's Avatar
My readings seem to be in line with the information Dave provided. To fully determine where my exact problem is I am going to need to know what kind of values would be on Pins 2 & 4, as these are what controls the gauge in the instrument cluster. After an hour or two of cool down it's reading about 200K ohms. Seems kinda high to me.
Still need more information....
Old May 17, 2007 | 07:10 AM
99A4NOW's Avatar
ttt
GM03Allroad
Oct 3, 2011 12:06 PM
katiebear00
Apr 6, 2010 01:58 PM
DurTTy
Aug 15, 2007 09:13 PM
mjvss21
Jan 7, 2006 07:03 AM
apoch
Sep 22, 2005 05:12 PM
