Need to replaced brake fluid. Need help
Old Apr 10, 2006 | 05:43 PM
dudley doright's Avatar
Default Need to replaced brake fluid. Need help
I want to drain all the fluid from the master cylinder but there is a strainer at the opening. How do you guys drain the fluid? Does that plastic strainer comes off?
Old Apr 10, 2006 | 06:00 PM
Jestnomen's Avatar
6th Gear
Default RE: Need to replaced brake fluid. Need help
How about draining it through the nipple on the brakes?
Old Apr 12, 2006 | 02:02 AM
dankhound's Avatar
Jest's idea is better but that strainer should just pull out. Just grab it around the sides with some needle nose. Be carefull not to get brake fluid everywhere as it will remove the paint from your vehicle.
Old Apr 12, 2006 | 03:39 AM
BadLuckAudi's Avatar
And when you replace the fluid make sure its the right stuff or you can **** up the entire brake system
Old Apr 12, 2006 | 10:06 AM
sandman's Avatar
yea, bleed them starting with the end farthest away from the mastercylender. so start with the passenger rear. hook a tube to the bleeder after you loosen it, drain it in to a bottle by pumping the brakes.
B5 Audi
Nov 27, 2009 05:24 PM
saga
Oct 24, 2009 02:07 AM
rink2rink
Jun 7, 2007 06:08 AM
