need wire colors for pass door lock
Old Dec 11, 2007 | 09:03 PM
Jits7's Avatar
Default need wire colors for pass door lock
Ok heres the prob.. I have a 96 a4 2.8 with an aftermarket alarm. Over time my driverside door lock stopped working when i inserted the key and turned to the right. usually locking the doors and arming the factory alarm. my more important problem is that my alarm is connected to the driverside door lock so now my car will arm but not lock the doors. my alarm is working just fine. I want to switch the wires to the passengerside where the key lock/factory alarm still works. I have the alarm diagram for the 96 a4 but it only shows the driver side lock. Also if this cant be done for some reason or not If theres a way to connect it to just inside lock which still works just fine and bypass the factory alarm im cool with that i just need my key less entry back!! Thanks a lot I got the diagrams if you need them to help me Thanks again for saving me from the stealership!!
gixxsta04
Jun 15, 2011 09:17 PM
gvj
Aug 19, 2010 06:17 PM
slideitsidewayz
Nov 23, 2008 05:32 PM
slideitsidewayz
Nov 23, 2008 05:31 PM
Jits7
Mar 8, 2008 04:55 PM
