Neuspeed 1.3bar on a K03Sport?
Old Sep 6, 2007 | 02:11 PM
cincyTT's Avatar
I'm make believe
Default RE: Neuspeed 1.3bar on a K03Sport?
ORIGINAL: onepoint8tee
Cincy you SOB
I guess i beat you to the punch
But your not making any more power after 21/22psi and no point in running it past there unless you run water/meth to drastically reduce the intake temps
Old Sep 6, 2007 | 02:12 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: DENIS415
see i didnt know that, because my last audi was the stock k03, so i knew that one couldnt do 20+ without a problem. So the FPR i have right now will do?
basically the same turbo and still possible with a ko3
onepoint8tee's Avatar
1.3 bar is only like 19 psi anyways. You might spike to 20-22, but spikes aint ****.
Old Sep 6, 2007 | 02:16 PM
DENIS415's Avatar
ok great thank you all for the input. im gonna pick it up saturday and have it soldered the same day. im also picking up the DV tommorow, anything else i should get with the Neuspeed setup?
Old Sep 6, 2007 | 02:20 PM
cincyTT's Avatar
I'm make believe
just free up the exhuast when you get the chance/funds
Old Sep 6, 2007 | 02:35 PM
khj677turbo's Avatar
I hated my neuspeed, it sucked alot. SO in consistent. But then again i hate my ko4, so w/e, im sure it will do just fine and it is free so have fun.
Old Sep 6, 2007 | 02:52 PM
cincyTT's Avatar
I'm make believe
Im betting you had a 1bar chip and bad boost control. With a good mbc or ebc and 19psi, im sureyou would of been more than happy.
Old Sep 6, 2007 | 03:22 PM
  #18
akielb's Avatar
anyone know why neuspeed wants people to upgrade to a 5-bar FPR and run plugs that are cooler and no one else does?
Old Sep 6, 2007 | 03:28 PM
  #19
cincyTT's Avatar
I'm make believe
All chipped cars should run one heat range colder plugs with a chip and gapped to .028 (same with dioded cars). There isnt a need for the increase in fuel pressure, just like there is no need for 380cc injectors @ 4bar with the APR tunes for the ko3s . Stock fueling is enough for the stock turbo.
ericp1.8T
Jan 31, 2011 02:19 PM
slopoke
Sep 22, 2008 12:06 PM
DENIS415
Jan 22, 2008 03:54 PM
mainer
Apr 1, 2006 07:47 PM
