new Forge 007p which spring for a chipped 1.8t
Old Sep 18, 2007 | 07:43 PM
pfeifstudd's Avatar
Default new Forge 007p which spring for a chipped 1.8t
I did a search and didnt find a clear answer, i am going in for the final dyno run on this new chip and want to get this thing on a dialed in right the first time. Its a stock 2004 A4 1.8t with the InMotion tuning chip, right now it peaks at 20psi and hold around 17-18 on the vag logs for boost.
There are three springs and two washer with this kit. The one that came in the DV was the green one, there is also a yellow one and a blue one.
Any help would be greatly appreciated
Old Sep 18, 2007 | 10:27 PM
pfeifstudd's Avatar
Default RE: new Forge 007p which spring for a chipped 1.8t
found my own answer, in case anyone else wants this:
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Old Sep 18, 2007 | 10:33 PM
TeeterTawter's Avatar
i used the green one when i had my forge dv
Old Sep 19, 2007 | 01:35 AM
Adam@mvp's Avatar
That is what I guessed when I read the post. Just like any other BOV. Just depends on how much boost you are going to run so that it can properly hold the pressure under boost without leaking off.
Adam~
Old Sep 19, 2007 | 03:24 PM
kemp_travis's Avatar
sorry to thread jack.....but are you happy and satisfied with your inmotion chip?
how much did it cost?
and how many days did it take to get it done? how long should i plan on not having my car running while its being chipped?
Old Sep 19, 2007 | 03:41 PM
pfeifstudd's Avatar
I have been really pleased with the chip, i did a baseline dyno a few weeks ago and then got the chip back last week and it really pulls now, it is peaking at 20psi and holding firm around 17-18psi. huge difference from stock.
I am doing a follow up dyno so we have some real world number on this chip, my next dyno session is sheduled for next tuesday, it was susposed to be yesterday but i didnt get my new DV in time so i had to reschedule.
I sent my ECU out on a monday and go it back by noon on wednesday, James is a real nice guy, and prompt with shipping.
Old Sep 19, 2007 | 08:11 PM
wow...that sounds nice
what was the total cost?, and what chip did you get?..or is there only ONE chip to get from inmotion.?
erroob0977
Apr 29, 2011 12:37 PM
dr_zoidberg
May 27, 2008 02:47 PM
randomloginname
Oct 25, 2007 12:23 AM
LaTeShifTT
Jun 7, 2007 02:49 PM
juice88
Sep 27, 2006 08:07 PM
