Forge 007p DV reversed??? help please
Old May 27, 2008 | 02:34 PM
dr_zoidberg's Avatar
Default Forge 007p DV reversed??? help please
Hi,
So I installed my Forge 007p DV a month or two ago, I installed it with the same orientation as the stock DV.
My friend said he saw a posting from a guy from Forge that this DV is supposed to be installed "reversed"? Is that true? I can't find this posting
Sidenotes:
Would this explain why around 4K revs I seem to have my boost shut off abrubptly? I have a ebc on the way that will display my boost level so I will be able to tell soon if I am not boosting right, but I still need to know if I should have reversed the DV
Also, if it is designed to be reversed, why would this be a better design then the regular orientation. Wouldn't reversing it just not allow the air to escape and possibly cause weird stuff to happen?
Old May 27, 2008 | 02:47 PM
cincyTT's Avatar
I'm make believe
Default RE: Forge 007p DV reversed??? help please
forge designs it to work the same way as stock. with it reversed you need more spring tension to hold the valve close and slower reaction. stick with stock
erroob0977
Apr 29, 2011 12:37 PM
randomloginname
Oct 25, 2007 12:23 AM
pfeifstudd
Sep 19, 2007 08:11 PM
LaTeShifTT
Jun 7, 2007 02:49 PM
juice88
Sep 27, 2006 08:07 PM
