ok, so ive been going into limp mode almost daily.
i decided to finally buck up and get the bentley manual and the ross-tech vag-com, i wanna take care of my car and do stuff myself, so here's my first scan... i wanna fix this damn limp mode problem, but i dont seem to be getting any codes... this is what came up (please bare with me, its my first time using this thing)
VAG-COM Version: Release 704.1
Data version: 20070422
Sunday,17,June,2007,21:51:53:25742
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 35: Centr. Locks Labels: 8L0-862-257.LBL
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06335
3 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
No fault code found.
End --------------------------------------------------------------------------------------------------
Coding: 16140
Shop #: WSC 06335
3 Faults Found:
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00101
Shop #: WSC 06335
So no codes for the engine? Crazy...
scan your engine see what codes come up then.
35-00 - -
00956 - Key 2
i always get thesefault codes each and everytime i scan my car and some cruise control code. never really took much care to them as they dontdo much,
I havnt scanned for like 2 months now. hmmmm.
35-00 - -
00956 - Key 2
yea i think i might go back out to the car and give it another run in a few minutes
maybe i need to get my car into limp mode again and scan it while its running? perhaps, i dunno since the limp mode goes away after i restart the car
Quote:
headshok2002
Date 6/17/2007 7:01:27 PM
headshok2002
if he scanned his engine it would have came out like this
saying no fault found with the adress and all there.
Coding: 00101
Shop #: WSC 06335
I've played around with the vag for hours, its fun!
weird when i try to scan the engine it says no response from controller...
yet the autoscan works fine... do i need to scan the car with it running?
sorry for the newb questions
scan the car with the car on power wise, doesnt need to be running.
gotcha! thanks
ok here are the codes... looks my o2 sensor is shot,and i'm pretty sure the engine torque monitor fault is what causes the car to buck, then cause the throttle to die with the epc light on... if i clear that code, would it help or would it keep coming back
(oh and i'm not saying to clear the codes in place of replacing the o2 sensor... just the etm fault)
Sunday,17,June,2007,22:25:44:25742
Address 01: Engine
Control Module Part Number: 4B0 906 018 P
Component and/or Version: 1.8L R4/5VT G 0006
Software Coding: 07201
Work Shop Code: WSC 06335
3 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
17743 - Engine Torque Monitor 2: Control Limit Exceeded
P1335 - 35-10 - - - Intermittent
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 01: Engine
3 Faults Found:
P1557 - 35-00 - -
the only time i get the "no responce from controller" is when the power to my car is off.
edit: you got it working...awesome
