no boost
Old Sep 7, 2006 | 05:44 AM
active1331's Avatar
Default no boost
why does my car only show 4lbs. of boost on my guage? the car feels a little slower. what the deal guys?
Old Sep 7, 2006 | 05:51 AM
socal_A4's Avatar
Default RE: no boost
boost leak? pop the hood and run a test to check it.. you might be able to hear it...after reading your sig, i think it is a boost leak for sure your chipped its common to spring a leak here and there when boosting more pressure.
Old Sep 7, 2006 | 05:54 AM
active1331's Avatar
is it maybe a DV valve?
Old Sep 7, 2006 | 10:41 AM
dafrazi's Avatar
That's the "hard" limp mode. My guess is the N75 is shot, disconnected, or the wires are broke at the connector to the N75. Check the car for codes; with boost that low I bet you have at least one.
Old Sep 7, 2006 | 10:48 AM
smokeU's Avatar
did you replace your DV when you got chipped? how long have you been chipped? my guess is DV.
Old Sep 7, 2006 | 03:15 PM
InsaneHatter's Avatar
your at 4lbs of boost and your car only feels a "little slower" ... WTF.. 12+ lbs of boost missing and you barely feel it?
maybe a bad line to the boost guage... a leak there could make it a little slower on boost
Old Sep 7, 2006 | 05:36 PM
active1331's Avatar
4 lbs in stock mode. i never replace the DV. i dont hear any leaks. WFT
Old Sep 7, 2006 | 05:42 PM
active1331's Avatar
O yeah it nevers drops below 0
Old Sep 7, 2006 | 05:56 PM
ahh stock mode.. stock boost is what 7-9? check for leaks, or a busted DV
Old Sep 7, 2006 | 08:51 PM
socal_A4's Avatar
Im calling it... its the DV... Why didnt you replace the dv when you chipped those mods should be done at the sametime. get a new dv and youll be good to go... dont get a cheap one... go forge or balieys... those type of companies I got a forge and im loving it..
