no boost
Old Nov 26, 2007 | 11:26 AM
limptimtim's Avatar
Default no boost
i have a '99 1.8T a4 tip with K04, dv 710n, giac chip.
I finally got around to installing a boost gauge and it is only reading 18in. vacuum at idle and spiking at 14-15 PSI
awe-tuning said i should be seeing 20-25 in. vacuum at idle and spike around 18-19psi with this setup that i have
i checked for boost leaks and can't find any. what are other areas of problem that might be causing the small numbers? are these numbers that awe-tuning provided correct?
thanks
Old Nov 26, 2007 | 11:42 AM
cincyTT's Avatar
I'm make believe
Default RE: no boost
18in hg is normal. You most likey have a weak 710 and should try a differnt dv. Just try flipping the dv around and see if it holds better to start.
Old Nov 26, 2007 | 05:31 PM
bob12312357's Avatar
IT's gods way of saying you shouldn't have gotten a tip.lol
Old Nov 26, 2007 | 05:37 PM
MrFlippant's Avatar
ORIGINAL: bob12312357
HAHAHA!!!
TeeterTawter
Jan 20, 2013 12:14 PM
to4xxx
Jun 8, 2012 11:56 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
eliTTe
Oct 11, 2007 04:12 PM
onepoint8tee
Jun 27, 2007 04:38 PM
