No Idle when cold outside
Old Dec 15, 2005 | 03:21 AM
mikehh's Avatar
Default No Idle when cold outside
I was wondering if anyone of you had a problem with the idle rpm when outside temp is wicked cold. Today we had something around 0F and for a period of 10 min, after driving for 30min, the idle rpm would drop until stall. This only happened twixe in the past two years. I thought that maybe a vacuum line might be frozen or so? Anyone ever had the same problem???
Old Dec 16, 2005 | 04:39 AM
Simone's Avatar
Default RE: No Idle when cold outside
same problem just started happening. once at the end of summer, and now recently that its cold out.
plus when i let it warm up in the morning the idle will drop way down and almost stall...
Old Dec 16, 2005 | 02:54 PM
mikehh's Avatar
does it seem to be running smoth but just drops the prm unit stall, or does it run chunky even in the upper rpm? how long does it last unit it runs better? does anyone have an answer to that???
Jackmup
Oct 29, 2009 01:28 AM
a4audia4
Jan 20, 2009 12:36 AM
jhsteel82
Jan 18, 2009 10:30 PM
horsecrazy8907
Nov 12, 2008 04:09 PM
mikehh
Feb 12, 2007 11:50 AM
